kendotelie
Hello. I'm in month #3 of owning the F150 Lariat, and I currently have on order a part thats supposed to fix an issue with an fault with the cab pro power system. This problem 3-4 weeks ago
Until today I had not made the connection that this issue may be related to water i have discovered today that is leaking into the cab from around the front passenger side door. The carpet is wet and I can very clearly hear water sloshing on the right side. I have heard this sloshing for a couple weeks now but assumed I had a bottle of water lodged somewhere. This is not the case. The water sounds like it's in the door and I even thought maybe underneath the cab (possibly battery compartment) but there are no clogs in the door. And now having found this water....
@Ford Motor Company for visibility
