Wheel well liners or photoshop?
bcaseyk
Casey
Austin, TX
2021 F-150 XLT FX4
I picked up the OEM wheel well liners from a local dealership today and threw them on when I got home from work. FordPass rewards FTW.
Also - CravenSpeed Stubby antenna.
Before
Ford F-150 Lightning Wheel well liners or photoshop? IMG_0504
Ford F-150 Lightning Wheel well liners or photoshop? 63710399765__C132B8B7-50D8-4A10-874E-D921F3E756D4
After
Ford F-150 Lightning Wheel well liners or photoshop? IMG_0506
Ford F-150 Lightning Wheel well liners or photoshop? 63710430965__DB43CE0F-9062-472D-BB07-5EC38D9FA5F0
KBKEITH
2021 F-150 XLT SCREW 5.5, FX4, 2.7EB
Before
After
Looks much better with the liners. I have a set of OEM liners on the way. Should look good with my Iconic Silver.
Jus Cruisin
Tim
Metro Detroit
2021 F150 Agate Black Platinum 4X4 Powerboost
Very retired
Rear wheelwell liners make a huge difference on light colors. Before liners I would take a spray can of gloss black to them. Even though my truck is black, I'll get some just to clean up the look.
discothan
SW Michigan
2021 F150 XLT
Just curious, those who installed their own wheel well liners, do you think that winter salt spray would get caught between the liner and wheel well? I'm hesitant to buy/install because I can easily spray down the wheel well right now.
I guess I could easily spray rust protection the wheel well before installing the liners.
bcaseyk
bcaseyk
Casey
Austin, TX
2021 F-150 XLT FX4
If it weren't for FordPass points from the purchase of the truck, which covered them completely, I definitely would've gone that route or maybe line-x.
The liners have a little bit of a lip that curves toward the bed that should catch most things from making their way in between the liner and wheel well. Other than this f'd up winter storm we just had in Texas, I'm not too concerned with that aspect. But, in an area like yours.. there are only four plastic clips and two 7mm screws that hold these in place - you could probably remove them, spray down the wheel well and backside of liner, then reinstall. Clips would more than likely need to be replaced, that may cost 99 cents annually. Sounds like a lot of work, but it seriously only took ten minutes to install both sides.
Lippy
CA
2021 F-150 Powerboost
Ha. I did the same and ordered liners and a cargo net with my Ford Pass points, plus a few dollars. I also got the same stubby antenna, and a LoMax tonneau, BedRug, and nice Lloyd carpet mats.
flatag
2021 Ford F-150 XLT FX4
Did you just do the rears? Are the front liners easy to install?
Smitdog
2021 F150 Limited PowerBoost Smoked Quartz
Gainfully Retired
Wheel liners make the truck look so much better / cleaner, it should be standard equipment on all trim levels. Very cheap part I'd imagine too.
CBGray
Chad
Washington
'21 Lariat 2.7L EB Screw 4x4 501A
Software
whats the product number? I want to make sure I'm ordering the right thing
Ford Part: ML3Z-9927886-A
They are $157.95 at Fairway Ford. That's where I ordered mine from.
