Gap between driver door and seal on 2024 Flash
Mars_Tuesday
Asif
2024 F-150 Lightning Flash
The gap between the driver door and the rubber seal is wider at the top corner, close to the B-Pillar (near the seat belt area), on my new Flash. It makes a rubbing noise when going over bumps, even at slow speed. The fitment on other doors is pretty snug. I’ve attached a picture of the area in question. Is it an easy door adjustment, or does it warrant a visit to the service center?
Ford F-150 Lightning Gap between driver door and seal on 2024 Flash IMG_1689
invertedspear
AZ, USA
lightningcalcs.pages.dev
Ok, so feel free to research this on your own, and please don’t just trust some rando on the message board, especially because this will sound like bullshit… but…
The way to fix this if the bottom of the door is fine but the top sticks out is to open the door, open the window, brace the middle of the door and CAREFULLY pull the top corner in. It’s aluminum, so this is going to bend a lot easier than my old 77 Chevy that my sister wrecked, but this is how we did it in our redneck garage. Be careful and good luck. Warning, I proudly wear the “I void warranties” t-shirt.
Ford Motor Company
Official Ford Account
Ford
F-150
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
Mars_Tuesday
Asif
My VIN is 1FT6W3L74RWG27152. My local dealer is Helfman Ford in Stafford, Texas. Thank you for your time.
