Jim Lewis
- First Name
- Jim
- Jan 10, 2023
- San Antonio, TX
- Honda Accord 2017; 2023 Lariat ER
- Occupation
- Retired
Since the "advanced" intrusion/inclination sensor system had to be removed from my 2023 Lightning, I thought I'd at least add the basic VSS (Vehicle Security System) module (ML3Z19A361A ) for the Ford Perimeter Plus Security System. Just installing the VSS module without the other options adds basic shock detection.
I have searched the forum and don't see anyone else discussing this option. But I figured since many forum members have owned tons of F-150s in the past, some folks may have had the same sensor in past vehicles and could comment on the installation and usefulness or not of the VSS device.
For starters, the accessories.ford.com site lists the basic module by my VIN # as working in my 2023 F-150 Lightning ER, although several other 3rd-party Ford parts sites say the item doesn't fit my vehicle!
Then, I asked my dealer Parts Department about labor charges for installing the module. I was told one hour for installation and one hour for "programming" the module. The Ford Parts site only quotes a $60 charge for dealer installation. And several YouTube videos and forum posts on other F-150 sites indicate that it certainly takes less than an hour to install, and if you're a whiz mechanic, it can be done in 20 to 30 minutes. The following guy is an ace mechanic. He installs the VSS and replaces all the paneling in about 20 minutes (it's a 2021 ICE F-150, IIRC).
In the above video, the mechanic had to remove the center AC control panel to get at the electronics. In a 2013 F-150, the module really is Plug 'N Play and just plugs into the OBDII port!
For my Lightning, it seems the installation will be more like the first YouTube video. The following Ford instruction sheet says the enhanced central gateway (ECG) connection point is located under the Front Display Interface Module, behind the sync module. I presume that means they'll be removing my Sync panel, etc. 2023_RMST_Common_I-sheet_9-15-22_FINAL.pdf (fordservicecontent.com) (see the top of page 4)
Various online posts say that the shock sensitivity of the VSS is not great if the device is bundled into harness wiring. The best place to put the shock sensor is on a metal plate under the steering wheel or on a metal support framework but in a way that the sensitivity dial should still be accessible.
Regarding programming, there seem to be a few simple steps to go into LEARN mode and integrate the device into the truck's security system. I don't need the remote start option or the optional LED arm status indicator, which reduces the complexity of activating the system. (see bottom of page 8 in the linked installation instructions).
Anyone else have experience with the VSS?
