Bed Tray (OEM) installed
GustaBusta
AKG
2024 Lightning
I installed the Ford bed tray (JL3Z99112A15E) on my 2024 Flash. I contemplated bed mat vs bed tray vs bed rug, and decided to go with the tray since the oem mat was out of stock when I placed the order. I used Ford points for the purchase.
I'd give the bed tray a 3.5/5 overall. I like the tray except for two things:
- the tray leaves about an inch of space on the sides between the raised lip of the tray and the body (see pic)
- the tray came with a stick-on tab that needs to be adhered to bulkhead, and the tray has a slot on the bulkhead end into which the tab needs to be inserted to hold down the tray. But, the bulkhead surface is kind of curved at the bottom and thus doesn't have a flat area to affix the stick-on tab flush to the body. You can see that the tab is floating above the tray and not under the tray. I hope I'm not doing something wrong with installing the tab.
I'd probably go with a bed rug if I get to pick again.
Ford F-150 Lightning Bed Tray (OEM) installed 20250203_143401
Ford F-150 Lightning Bed Tray (OEM) installed 20250203_143412
Ford F-150 Lightning Bed Tray (OEM) installed 20250203_143434
Ford F-150 Lightning Bed Tray (OEM) installed 20250203_143422
Danface
Dan
Central Mass
2023 Lightning XLT
I have a bed rug and like it a lot. It makes no sense that the fit wasn't better?
NikonJim
2024 F-150 Lightning Flash
I went with the rubber bed mat. Happy with it, I used points too.
jweggy
Joshua
2024 Ford F150 Lightning Lariat 2021 Ford Mustang MACH E GT performance edition
What bed rug did you go with? Any pictures of the install? Link to source where purchased? Have youuled anything that would require cleaning it? Is cleaning a pain?
Danface
Dan
Central Mass
2023 Lightning XLT
I got the Bedrug brand and I put a rollup tonneau cover on it to keep from getting too messy. I have a little plug in vac I keep under smaller rear seat to clean the truck when charging and have had to vac a few time before getting the cover. I could see it getting somewhat narly if it wasn't covered or keep pretty clean. The cover is also helpful in the snow.
I'll add pics tomorrow
mrau
23 Lariat⚡ER
The Bedbug is almost a plastic like fiber more than cloth.. It is very easy to clean. I do have a Revolver X4s rollup tonneau cover on truck which helps a lot.
Not hard to install. Sunny day helps. There are a few install videos out there as well.
Shop around for best price. Amazon does carry them.
Ford F-150 Lightning Bed Tray (OEM) installed IMG_2510
Ford F-150 Lightning Bed Tray (OEM) installed Screenshot 2025-02-04 at 6.07.05 PM
jweggy
Joshua
Looks great! Thanks for information and pictures. Much appreciated!
jweggy
Joshua
@mrau
