Box Link Cleat Install Problems
Lpetters84
Landon
Kentucky
2021 F-150 Platinum FX4 5.0
Hey Guys,
Has anyone else had issues installing the Ford box link cleats in their bed? I got one of the 4 in place. There is no way the other 3 are going in. Without some sort of modification.
BMWtoF150
Marty
SC
2021 F150 King Ranch, 3.5 Eco
Retired, Part Time Consultant
Hey Guys,
Actually, if you hold them exactly square to the plate, they will wiggle in.
Dan M.
Dan
Fayetteville NC
2018 Ford F-150 Lariat
Retired Army
Hey Guys,
I used a little oil on the cleat and it slid right up. You could use a little grease also or use a small file on the cleat.
Lpetters84
Lpetters84
Landon
Kentucky
Thanks. Iā€™ll give it a shot.
Chewza
Matt
Glen Allen, VA
'21 AMB Plat PB
Oddly enough I just got done installing mine after my Retrax Pro XR.
They slid / wiggled right in with very little resistance.
Lock side down, ensure it's unlocked by turning the key clockwise, and slide that shit in.
Was done with all 4 in less than a minute.
Lpetters84
Lpetters84
Landon
Kentucky
Oh man. Iā€™ve been messing with these dang things for 45 minutes and Iā€™m drenched in sweat. I had the factory spray in bedliner. I wonder if that creates a tighter fit. Iā€™ve even beat on the damn things with a rubber mallet..
Fredm2002
Fred
Iowa
21 Platinum Antimatter Blue; 2018 Edge 1984 V-65
Education
I had to remove the bracket to install the cleats. The factory spray-in Bedliner was preventing the install. Took about 15 minutes total to remove them and reinstall them.
jmacd
Forest Knolls, CA
2021 Ford F150 XLT 3.5 HDPP, Stone Gray
These arenā€™t easy to install! I lightly tapped them up in the mounting plate with the rubber hammer and was able to then lock ā€˜em in place. Persever Lpetters84.
Pilgrim
Everett
2021 F-150 XLT Sport
Retired Soldier
Same problem here. I had to drive the screws in with a drill (they are self tapping) and then bang the cleats in with a rubber mallet. The tolerances are so close they just seem to need some good persuasion.
Chewza
Matt
Glen Allen, VA
'21 AMB Plat PB
Odd, my brackets weren't covered in the factory bedliner material.
Lpetters84
Lpetters84
Landon
Kentucky
Mine arenā€™t either. That is odd that yours fit and mine are not even close
jcaspar
Sacramento CA
2021 F-150 4x4
I have factory bedliner too. Mine were preinstalled but really hard to replace when I removed one. Filed down a little of the plastic to make it fit easier
xtraman122
Pete
MA
ā€˜21 302A PB
Weird, I have a factory spray in liner as well, mine went in pretty much effortlessly.
Lpetters84
Lpetters84
Landon
Kentucky
Well they are finally in. 1 hour later and Iā€™m pretty sure I lost 10lbs from sweating my ass off in the garage haha. I had to file the plastic inserts on the back side of the cleat and it went right in.
looks like the plastic injection mold didnā€™t have a clean cut when breaking from the mold.
SuvE
Gary
Arizona
2021 F150
My dealer installed mine prior to delivery. :)
