PungoteagueDave
AMP has just begin to ship their new bed step that installs on the driver's side corner of the 2021 F-150 bumper. I've used their steps on prior trucks and waited for this version to become available for the 2021 model. They tell my I got the first one shipped, and it showed in the installation instructions, which missed a couple steps, but I was able to figure it out and get it installed. The competitor's Bestop step model has been available for a couple months, and it can be installed on either side, while the AMP BedStep installs only on the left side. The difference is that the Bestop step hinges straight back, so remains entirely UNDER the open tailgate, while the AMP BedStep hinges 45 degrees to the left, so it is outside the tailgate, a far better format for stepping up onto the tailgate itself. Glad I waited.
The installation is fairly straightforward, involves removing two large bumper mounting nuts (24MM - few wrench set have this - a 15/16" will substitute, but again, you may have to search for this). You will need a torque wrench capable of 129 ft-lbs for reinstalling those nuts. To complicate it a bit, the nuts are inset in a "box" and you access them through holes provided for that purpose - but the holes are just slightly too small for my 15/16" deepwell impact sockets to fit. I was able to put a shallow 15/16 socket on the nut inside the "box" and then put a short extension through the provided hole, onto the socket, and then install the torque wrench onto the extension. There are a couple other nuts that are a bit tough to reach and must be torqued blind because they are on top of the unit where you can't see them after installed. But, wow, when it is done, it is super-solid, will hold anyone, flips in and out easily.
Ford sells the AMP BedSteps as factory options on Superduties, so they may become available for configuration on the F-150, just as they recently added Retrax bed covers as Ford-branded options in 2021 due to popularity with Ford truck owners.
Here are a few pics. The last one shows how it protrudes to the side when deployed. Sorry about the dirty truck, we're currently at the farm with a mile-long gravel driveway.
I ordered mine direct from AMP. Interestingly, they still shown on the AMP Research website as "coming soon" but this one came yesterday and here it is. It looks like you can complete an order but it says 6-8 weeks for production. Mine might be a prototype - and I hope they improve the instructions - there were a couple critical bolts that were not pictured in the instructions - it was obvious to me where they went, but some folks might not figure it out - and the bolts for the step itself went in different holes than the ones pictured in the instructions. But all in all, a great addition to the tailgate step that comes with the truck, especially if you tow a lot and cannot use the tailgate step when hitched up.
https://www.amp-research.com/bedstep-bumper-step/2021/ford/f-150
AMP Part #75328-01A
AMP Part #75328-01A
