2021 F150 Lariat 502A bumper removal
jrhoops
JR
21 F150 SCREW, 35L-PB
I watched mr_boom5.0 youtube video, he had the grille out but stated in the comments it's not required. I looked under the front end and can see 2 nuts on each side but can't figured how to to get to the other 2 that are more centered. Also, not sure how the bolts come out or are they attached to the bumper permanently/? Any advice or pictures would be appreciated, I am attempting to add a couple washers as a bit of a spacer for the bumper.
Doyouevenboost
2002 Subaru, 21 f150 502a ecoboost
Utility maintenance worker
Grill 100% has to come out, i had my bumper off yesterday.
i have a 502a ecoboost so disregard some of the connections if it doesnt relate to you.
NOTE: Removal steps in this procedure may contain installation details.
  1. Remove the push pin retainers, position aside the air intake duct, and remove the air deflector.
Ford F-150 Lightning 2021 F150 Lariat 502A bumper removal {filename}
Ford F-150 Lightning 2021 F150 Lariat 502A bumper removal video
Ford F-150 Lightning 2021 F150 Lariat 502A bumper removal Hel
  1. NOTE: If equipped.
    Disconnect the electrical connectors and washer hose.
  1. Raise the vehicle on a hoist.
    Refer to: Jacking and Lifting - Overview (100-02 Jacking and Lifting, Description and Operation).
  1. On both sides.
    Remove the 2 screws.
    Torque: 15 lb.in (1.7 Nm)
  1. Remove the front bumper upper cover trim panel.
    • Using a flat-blade screwdriver release the locking tabs
      Use the General Equipment: Flat Headed Screw Driver
  1. Remove the bolts and the pin-type retainer.
    Torque: 36 lb.in (4.1 Nm)
  1. Remove the active grille shutter mounting bolts.
    Torque: 159 lb.in (18 Nm)
    • Remove the pin-type retainer.
    • Pull up to disengage the locating pins along the top of the grille.
    • Pull forward on center of the grill to remove.
Removal
NOTE:
  1. Remove the radiator grille.
    Refer to: Radiator Grille (501-08 Exterior Trim and Ornamentation, Removal and Installation).
  1. NOTE: The number and location of electrical connectors and retainers will vary depending on option content.
    1. Disconnect the turbocharger bypass valve electrical connector.
    1. Detach the wiring harness retainers.
    1. Disconnect the front bumper harness electrical connector.
    1. Disconnect the lower active grille shutter actuator electrical connector and position the front bumper wiring harness aside.
  1. If equipped.
    Release the tabs and remove the license plate bracket.
  1. If equipped.
    1. Detach the wiring harness retainer.
    1. Remove the engine block heater and position the engine block heater wiring harness aside.
  1. With the help of an assistant.
    Remove the nuts and the front bumper.
    Torque: 76 lb.ft (103 Nm)
jrhoops
JR
thank you sir, I had the grille of changing the emblem. uncertain if I will do what I am thinking of doing haha
SFD9
Wisconsin
Raptor, 2021 f-150 on order
Self
Removed my bumper, did Not have to pull the grill off. Just the trim piece underneath, 2 screws on either side & a bunch of clips.
@Doyouevenboost i see you have ford manuals, can you identify the 4 wires going into my LED fog/drl please?
Doyouevenboost
i included the entire headlamp system since its all tied together, and im not sure exactly what you were looking for.
PinCircuitGaugeCircuit FunctionQualifier
1CBBA0 (YE-VT)22FUSE - 100 OR CIRCUIT BREAKER
2VLF89 (BU-RD)20CTRL MOD. - HEADLAMP # FRONT FOG
3CLF61 (GY-RD)22CTRL MOD. - DAYTIME RUNNING LIGHT LEFT
4GD129 (BK-YE)16GROUND - HEADLAMP PANEL/GOR LEFT
Ford F-150 Lightning 2021 F150 Lariat 502A bumper removal 1630365603060
Ford F-150 Lightning 2021 F150 Lariat 502A bumper removal 1630365734274
Ford F-150 Lightning 2021 F150 Lariat 502A bumper removal 1630365773507
SFD9
Wisconsin
Self
Thanks I think that will help.
I’ve got Rigid LED fog lights to replace the factory ones. The problem is it made the check engine light come on because the DRL circuit is open now. Soooo, I got different Rigid Radiance LED lights with a white backlight, To act as the DRL’s and the lower power center to be the fog lights.
It’s using pin 2&4 now I believe, need to hook the backlight up to pin #3 & hoping it makes the CEL go out.
