What is the max trailer towing capacity of the Limited PB with class IV hitch? What is an upgraded bumper of the max towing pack as the hitch connects to the frame?
Thanks
What kind of trailer do you have? That will be my next purchase, would really like an enclosed trailer to tow my Evo to track events, but not sure I can get an enclosed trailer + a 3500 lb car + tools and tires and such in under the 12,400 limit. It might be close, and I really don't want to pull at the max all the time. I'll only use it 8-10 weekends a year probably, and all on pretty flat highway. Having to go with an open trailer won't be the end of the world, but enclosed would be nice for the security during the nights the trailer stays at the track and I'm across the road in the hotel.Towing a race car and everything is in the trailer. So for me it is a matter of tongue weight and towing capacity. The max towing package on my 2017 with ecoboost/10 speed is awesome. I can't tell I have a trailer behind me. Judging from the specs on the PB it should not be an issue.
Look for a used Featherlight trailer, if you can keep the trailer to under 7k you should be good;What kind of trailer do you have? That will be my next purchase, would really like an enclosed trailer to tow my Evo to track events, but not sure I can get an enclosed trailer + a 3500 lb car + tools and tires and such in under the 12,400 limit. It might be close, and I really don't want to pull at the max all the time. I'll only use it 8-10 weekends a year probably, and all on pretty flat highway. Having to go with an open trailer won't be the end of the world, but enclosed would be nice for the security during the nights the trailer stays at the track and I'm across the road in the hotel.
You have anyone ride with you, have a bed cover, bed liner? All that counts against the payload number. WDH is 100 pounds, plus if you are pulling a 9-10K trailer with a car in it that could easily drop 1200 pounds on your hitch.Towing a race car and everything is in the trailer. So for me it is a matter of tongue weight and towing capacity. The max towing package on my 2017 with ecoboost/10 speed is awesome. I can't tell I have a trailer behind me. Judging from the specs on the PB it should not be an issue.
Thanks Mat for the math. Let's get out the sharp pencils:
Driver per the Ford Towing Guide 11/24/20
"Maximum towing capabilities are for properly equipped vehicles with required equipment and a 150-lb. driver and passenger and vary based on cargo, vehicle configuration, accessories, option
content and number of passengers. See label on door jamb for carrying capacity of a specific vehicle. For additional information, see your Ford Dealer."
Trailer Loaded per CAT scale:
8400#\tongue weight 850#
Recap:
850 Pound hitch weight,
100 pound WDH
45 pound bedliner
70 pound cover
Included driver & passenger
1065# - so in my case it works, just close.
Thanks
I typoed the year before it was 2016 they revised it. I do not work for Ford. Normally weight is not an opinion but a fact in most peoples opinion...Matt,
Are you in SAE? I could only find a Feb 2020 revision, before that 2016. If you are engineer with Ford that would make this conversation fact and not opinion. If you are then I have a few more questions.
I appreciate the exchange.
Tim
