22 Lightning Lariat ER leaking MASSIVE amounts of water under chassis
Icruz101
Isaac
Waco, TX
2023 F-150 Lightning
Hello all, just bought this truck 8 days ago and I’ve noticed that it leaks an absolute metric crapton of water when the AC is running. I understand most all vehicles have some condensation but this is more than I have ever seen in my life. Also, I have noticed some condensation around the vents as well. Anyone else had this issue? Should I take it to the dealership? Tyia for feedback.
Condensation is a function of barometric pressure, humidity and temperature. I say this because the dealer is going to tell you that without fully understanding what’s happening. You could be having an unber efficiency problem if that’s what you’d like to call it. Hopefully your dealer will be empathetic and find a cause and solution you’d be pleased with. When I bought my 23 Lariat, the combo valve had a leak and I got nothing but heat in the hot Texas summer. It was not an immediate fix. They had to use dye to find the leaking seal. So much for QA.
