What app are you using on your tablet?
CarScanner, using an OBDLink MX+ piece of hardware to pull data from the truck. I'm recording the entire session so I can better understand what my options will be if I need to do this again. For today, I shut down my high performance computers and need to know whether this small draw is at all an issue.What app are you using on your tablet?
This is the quintessential use case for this truck. Absolutely amazing. It tows, it runs tools on-site, and it is the "supervisors office" with the work surface. You lived an honest to god Lightning commercial right there.Completed my first serious tow today. I towed a small tractor on a midweight trailer with surge brakes. The total weight was about 6000 pounds.
The one-way distance was about 50 miles freeway and about 5 miles on poorly-maintained gravel then dirt road. Elevation change was about 2500 feet down outbound and 2500 feet up on the return.
On the drive out, I had a passenger and we ran the AC at relatively low temperature. The outside temperatures were in the high 90s once we got off the mountain and above 100 by the time we got to our destination. I set the cruise control at 73. The efficiency out was 2.2 mi/kWh.
The truck was powered on for about 9 hours as I was using the jackhammer and several other power tools.
I also took several meetings in the truck so had the AC running for about four hours total. The outside temperature was 100+ and it was very humid.
The jobsite is not mine. It has a bunch of crap everywhere, and the rear driver's side tire was punctured. So I had to swap to the spare. It was getting dark by the time I finished that fun first, which came with the added complication of having a loaded trailer hooked up with nowhere to drop it.
On the drive back up the mountain, it was storming, so I stayed at 65 mph once on the freeway. AC was on for only the first 5 miles. The efficiency home was 1.1 miles per kWh.
The total distance driven was about 120 miles. Final SoC displayed is 39%. I believe almost 10% was non-driving use.
I think I'm happy with this. Most of the towing I'll be doing will not be with this kind of load. Almost none of it will include running the onboard power for 9 hours, nor multiple meetings taken inside the truck with the AC blasting.
I didn't like the stock tires for towing. They are mushy and seemed to be just passable as a 116 load rating. I'll likely get a set of tires with stiffer sidewalls at some point
I also don't like the trailer's surge brakes when towing with one pedal. I'll have to try shutting it off next time.
Oh, and Ugh. I had to stop for diesel on the way out.
One of the several reasons for choosing the Lightning was for this exact purpose. I've gotten more use out of it in just a few short months than most of my other trucks after years of ownership.This is the quintessential use case for this truck. Absolutely amazing. It tows, it runs tools on-site, and it is the "supervisors office" with the work surface. You lived an honest to god Lightning commercial right there.
