B & O Unleashed
NY Cowboy
Jeff
Miami, FL
2021 F-150 Lariat & 2015 Transit T-250
Contractor
I basically listen to sat./radio and no sound from any of the speakers except the front center top dashboard. The audio setting on on Sound sound not stereo. Any suggestions or will I need to bring it in to the dealer?
scott011422
Scott
2022 F150
Its my understanding that most of the speakers will not work with sat radio in surround mode. There is too much compression. Some say it will work better in stereo mode.
Personally, with the unleashed, You need to listen to HD content if you want the speakers to work. Amazon HD radio, Tribal for sure. I'm not sure it pandora or Spotify offer an HD service.
tbinmd
18 KR F150
bgator
FL
2022 F-150 Platinum
Mine is the same. I think it’s just the way the B&O system is designed.
I can’t tell a significant difference between stereo and surround, but moving the sound field back toward the middle of the cab helps.
Satellite is terrible for sound quality. It’s a limitation of the technology. I’d use a high quality steaming service, like Apple or Tidal, when judging the quality of the system.
I find some songs are more center heavy and others not so bad. Maybe the mixing of the songs comes into play too.
Hellphire
Midwest USA
2013 Lariat FX4 3.5EB
Iron casting foundry
I have unleashed and I get sound from all the speakers regardless of source or stereo/surround setting. As should you. Also note* that the sound does get better depending on the source though.
scott011422
Scott
2022 F150
spud_41
Mountains & Desert
'21 Lariat 502a, Lead Foot 3.5L EB Fx4
If you think your speakers aren't working, press and hold the next track buttons (1: on steering wheel, 2: on dash) and it should make all 16/18 speakers beep one at a time.
Everybody else is correct though, check the fuses, try a much better audio source, try restarting Sync 4. The Unleashed is very front center heavy even in surround unless you adjust the fader just behind the front seats.
NY Cowboy
NY Cowboy
Jeff
Miami, FL
Contractor
I tried it nothing happend.
BMWtoF150
Marty
SC
2021 F150 King Ranch, 3.5 Eco
Retired, Part Time Consultant
My unleashed is set to surround. I get sound from all the speakers whether using XM, USB stick, CarPlay, or HD Radio.
spud_41
Mountains & Desert
Just double checking, you pressed and held these two buttons together and nothing happened? I'd try resetting the sync 4 and if that doesn't work you might need to try the dealer.
Ford F-150 Lightning B & O Unleashed 20220319_143847
Ford F-150 Lightning B & O Unleashed 20220319_143853
NY Cowboy
NY Cowboy
Jeff
Miami, FL
Contractor
Yes and with the truck "on".
Jesse-Infotainment
Jesse
Dallas
2024 F150 Lightning Flash
The 18 speaker system powers the Rear doors speakers and front tweeters from the Audio Control Module and all the others powered by the DSP on the back wall behind the driver side rear seat. If only the center is playing that is strange.
FXDR131
Paige
NH
2019 XLT SC Sport - On Order - 2022 Lariat SC 4x4
Business Owner
Spotify does if you pay for their service.
NY Cowboy
NY Cowboy
Jeff
Miami, FL
Contractor
Thanks for the offer, I am in Miami, FL. I will take it to the dealer
