Janesy
- First Name
- Chris
- Jan 20, 2022
- F150gen14.21912
- 2021 F150 HDPP
so I just took owner's of a 2021(in)2022 but whatever haha) F150 HDPP. It does everything... Except make a darned phone call.
Every other f150 if had you simply push the button, say the words and it makes a phone call. Not this one.
This one, after you speak the words, it turns on Google assistant and asks you to unlock your phone?? Ok. So unlock the phone. Try again, after about 15 seconds it makes the call. Mean while your phone is going nuts trying to offer Google assistant options. But after you hang up the call, it doesn't go back to the radio. It stays as you phone as the source, until you manually select radio as the source again, after which it goes back to the radio.
So background info, I didn't think I even had Google assistant. I've never used it before. The setting to allow Google assistant to work with a locked phone is on, and correct.
It almost as if the truck is recognizing that it needs to make a call, but Google assistant on my phone doesn't want to talk to the truck. Then the truck stay locked in the phones source output waiting for music.
Frankly, this is rediculous for what I just paid for a darned work truck. It should be able to make a phone call without giving me Google options.
But I cannot seem to make the truck work, if I disable Google assistant.
