Cool way to view APIM AS-BUILT Data
heffer86
Iowa
2021 F150 Lariat 501A
I was playing around with the Bezel diagnostics. (Steering Wheel Next track + Radio Controls Next Track) I found if you go into the APIM section and view the "Configuration" section it shows all the AS-BUILT data in easy to read format. Cool way to see if the FORScan changes have taken affect.
Sorry for the poor video.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Yeah, this has been around since the Sync3 days.
It's easy to forget it's there
Ajzride
Alan
Houston
Eng
1-pedal? Is that a carry over from the Mach-E or is there a way to turn that on for the PB that I’ve missed?
iceman77
Pete
2022 Ford F-150 Platinum
Can someone remind me how do you activate "Bezel diagnostics" on the 2021/22 F-150s ?
Zyvin
SC
2021 F150 Crew, FX4, Lariat
I think they are similar in function but for the EV it’s more for regenerative braking, in the F150 it’s more for off-roading.
Ajzride
Alan
Houston
Eng
I didn't look under off-roading. I was interested in using it for regenerative braking on the powerboost, I've grown really fond of 1-pedal on my Mach-E.
tonesto7
Anthony
1-Pedal is only available to Tremor and Raptors :(
I don't know if PCM firmware needs to be different but turning in only in Forscan has no effect
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
Make sure you're in radio mode and then simultaneously press and hold the Skip FWD buttons on both the steering wheel and under the display.
sbi
Upstate SC
2021 F-150 5.0 Lariat SCREW Space White
So it's the HVBom list that a dealer can print out for you.
Most importantly - how do you get out of this? :D
Bob_Mac
Bob
North Carolina
Keep hitting the back button on the display... worked for me.
Reactions: sbi
