Heated steering wheel and wheel tilt broken, 6 days with dealer and no fix in sight
Maverick, mustang
Not sure of exact timings since I don’t use either often or in summer, but at some point my heating steering wheel AND the adjustment for steering wheel tilt stopped working. This is on a ‘23 Lariat ER. Oddly the wheel will still retract/extend when you start/stop the truck but the controls don’t work and it does not adjust to driver profile.
Dealer has had it 6 days now with no solution in site. Apparently they are now convinced the problem is not the electronics in the wheel but in a module in the drivers seat. Seems odd to me. Also very surprised such a simple thing can take so many days to diagnose and fix.
I’ll reply to this post again when they do finally get it sorted to confirm total days and root cause of issue.
Wondering if anyone else has had similar issues? Does give me concern on what happens with non-warranty issues. A heated steering wheel should not be something that takes days to fix!
Ford Motor Company
Official Ford Account
Ford
F-150
Good afternoon! If you'd like to, go ahead and send us a private message with your VIN and dealer info and we’ll look into these concerns. Thanks!
Maverick, mustang
Don’t think many folks will be surprised the dealer called me today and said the driver seat module did not fix the problem. They said they are out of options and have to contact Ford for next steps. So that’s now 7 days and counting to fix a heated steering wheel….
Montecarlossfan
Connecticut
2023 Azure Gray XLT Lightning
Programmer
One would think these are the exact same as the standard f150… shouldn’t be rocket science… maybe a different dealership going forward is the answer.
Maverick, mustang
I agree with you, should not be rocket science. This dealer is 30 mins away, biggest in the area with most BEV techs. Next closest is just over an hour and one recently certified BEV tech. Realities of rural living 🤷🏼‍♂️
What I also didn’t mention is the first time they had the truck for three days and gave it back with no fix the air bag error light was on and steering wheel had been reattached 90 degrees from straight. Really gave me confidence….
