Help upgrading stock audio system
Sancheznan25
Adrian
Ripon
2021 Ford f 150
Hey guys, so I don’t know much about audio systems and stuff but I want to upgrade my stock speaker system. Any ideas what speakers or subs or even any specific setups I should get. Any ideas helps!
Wakevictim
Stephen
Juneau AK
2021 XLT 3.5L eb
Military
You can install component 6x9s up front and the head unit has a built in dsp so you don’t have to use the crossovers that come with the set. You can install 6.5s in the rear and the easiest is to use coaxials.
Plug and play fronts: https://www.crutchfield.com/p_091ISFOR69/Focal-Inside-IS-FORD-690.html?tp=105
rears: https://www.crutchfield.com/p_091ICFOR65/Focal-Inside-IC-FORD-165.html?tp=105
The simplest way to install a sub is to install a LOC (Line out converter). You don’t need anything fancy but you will need an amp and wire kit. I used a Scosche LOC90 Speaker to RCA Line Output Converter. This will allow you to run a signal for the amp. This is installed behind the head unit. Check out the pictures of my install.
Ford F-150 Lightning Help upgrading stock audio system 3A170451-BC27-4609-963E-A2FFA27D961E
Ford F-150 Lightning Help upgrading stock audio system E9C3254B-502D-4CEC-9EF3-18E4362A9DED
Sancheznan25
Sancheznan25
Adrian
Ripon
2021 Ford f 150
Thanks for the info! Will definitely look into it!
Wakevictim
Stephen
Juneau AK
2021 XLT 3.5L eb
Military
Also. Here is the wire diagram for the stock 6 speaker system to match any line or Converter.
Ford F-150 Lightning Help upgrading stock audio system F75C82D2-73E6-4BB5-B031-866B72EEB6A4
