Stage3Motorsports
Join Noah for another how-to Video
Have you had any thoughts about designing a fog light add-on for the Lightning?I think this post is prior to the merge and was part of the 14th Gen forum
Theres no opening. And even if we drilled into the plastic bumper, there is technology behind there it would interfere with. I don't think there will be any fog kits for this truckHave you had any thoughts about designing a fog light add-on for the Lightning?
I wondered with all of the drive-assist sensors…too bad…those of us in the PNW and elsewhere that sees heavy fog could really use the option…..Theres no opening. And even if we drilled into the plastic bumper, there is technology behind there it would interfere with. I don't think there will be any fog kits for this truck
Yep, dense fog here the Willamette over here. Trying to think of a way to add fogs without screwing with the aerodynamics.I wondered with all of the drive-assist sensors…too bad…those of us in the PNW and elsewhere that sees heavy fog could really use the option…..![]()
Let me know if you figuire it out……….Yep, dense fog here the Willamette over here. Trying to think of a way to add fogs without screwing with the aerodynamics.
I have a potential DIY solution.Let me know if you figuire it out……….
I saw those to enhance the backup lights ….was hoping they will come out with a Lightning-designed wiring solution…..hadn’t thought about using it the other way….I have a potential DIY solution.
Installing this upside down on our required Front License plate. With a switch in the cab. My biggest concern is how wide the spread might be.
https://www.vleds.com/lp-reverse-72-w-5500k.html
