Lightning a/c issues??
Aaron
Aaron
Weymouth
2023 Ford lightning
Construction Engineer
Has anyone experienced an a/c issue with their lightning? I had it on 2 which was comfortable and all of a sudden it wasn’t comfortable anymore so I turned it up all the way and you can hear the air moving but almost nothing comes out of the vents. I have a 2023 XLT with options. This isn’t the first time this has happened to me either
The other day I notice one vent was not flowing air, looking closer I found that I had move the direction louver to far closing off the air flow, reset it and performance improved.
I tend to keep my setting on AUTO-3, then adjust the TEMP level down (colder) if I want more flow & chill, conversely in winter I'll bump it up several degrees to dynamically increase the conditions (Hotter) air flow rate, this eliminates fussing with the fan speed button.
G-Zeus
Garth
Massachusetts
22-F150 Lightning Lariat SR
I discovered that while driving in 65 degree temps, with the AC set to 68, that the heat turned on! So double check for that when it's not hot but you still want a cool cabin.
trev5150
Trev
Pilot of pilotless things
Yep it did what you told it to do.
