joesrepsol
Joe
Rocklin, CA
2022 Ford Lightning Lariat
Solutions Engineer
@Ford Senior Master
Any tips on removing the plastic panels, etc to get to the dash cluster? Trying NOT to break anything to install the new speedo calibration tool... panel with start button seems confusing... Trying to get this apart correctly and not break something.
Any help would be GREATLY appreciated.
Ford Senior Master
Ford Senior Master
Pell City, Alabama
Lightning Pro, 2023.5 MachE on the way
Service Manager
@Ford Senior Master
It is not that difficult. Be careful removing the strip of trim which goes from passenger side to steering column. Only pry next to clip locations. You should be able to slide your tool gently under the trim and locate the clips. It seems like a lot of trim but it all snaps in place with the exception of lower steering shroud. If you need more detailed instructions message me your info and I'll send the procedure.
