NEW PRODUCT | 7-Pin Trailer Harness Dual Reverse Kit w/Diode Dynamics Lights
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Drug Dealer of the LED World
So we put together a new product for everybody. This is pretty universal so it'll work on any vehicle with a 7-pin trailer harness connection. We've been planning this kit for a while due to the need for a SIMPLE kit to install on any truck AND much needed reverse lighting.
https://www.4x4truckleds.com/7-pin-trailer-harness-dual-reverse-kit-w-diode-dynamics-lights/
This is a completely bolt-on kit offering a simple plug and play installation (if your truck is equipped with a 7-pin trailer harness). The kit utilizes the Diode Dynamics 7-pin dual-output trailer wiring harness, which plugs in-line with your existing trailer harness behind your hitch. This configuration ensures you retain functionality of your trailer harness while keeping the plug behind the trailer hitch out of sight. Completely plug and play!
The kit includes a a red back-light feature which creates a red glow from the light housing whenever your indicator/headlights are on. As soon as you switch into reverse this red light turns off and the main white output turns on, giving you some much needed visibility behind your truck.
The included KR Off-Road extension bracket allows the lights to hang from factory bolts under your truck. This bracket is made right here in the USA out of 11 gauge stainless steel (and powder coated black) ensuring a lifetime of durability.
Included:
  • 2x Diode Dynamics Lights
  • 2x KR Off-Road mounting brackets
  • 1x Diode Dymamics 7-Pin Dual Output Trailer Wiring Harness
As stated, the kit utilizes our USA Made KR Off-Road brackets to hang the lights from almost any bumper (right under the bumper) and bolts right up using existing bolt holes. There's nothing to cut and no wires to run really. You simply unplug the factory 7-pin trailer harness from behind, plug in the Diode harness and plug the lights in. That's it!
Again available here: https://www.4x4truckleds.com/7-pin-trailer-harness-dual-reverse-kit-w-diode-dynamics-lights/
awilli1010
SE Michigan
22 lightning lariat er, 22 maverick, 98 FLHT, and a schwinn bicycle.
Does it have any effect on the lightnings tow mode?
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
Some photos we recently took
Ford F-150 Lightning NEW PRODUCT | 7-Pin Trailer Harness Dual Reverse Kit w/Diode Dynamics Lights 1672017687445
Ford F-150 Lightning NEW PRODUCT | 7-Pin Trailer Harness Dual Reverse Kit w/Diode Dynamics Lights 1672017691602
Ford F-150 Lightning NEW PRODUCT | 7-Pin Trailer Harness Dual Reverse Kit w/Diode Dynamics Lights 1672017696112
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
just placed an order, can't wait!
I hope you post pics. I've been looking at these, but there's so many options (1,2,3 sport, pro...) I gave up 😁.
drag0n
Kevin
F-150 Lightning Lariat SR
Finally got to installing them. They’re really bright and look great! Sorry for the crappy pictures.
Lights: SSC2 Sport
Ford F-150 Lightning NEW PRODUCT | 7-Pin Trailer Harness Dual Reverse Kit w/Diode Dynamics Lights IMG_2770
Ford F-150 Lightning NEW PRODUCT | 7-Pin Trailer Harness Dual Reverse Kit w/Diode Dynamics Lights IMG_2740
Ford F-150 Lightning NEW PRODUCT | 7-Pin Trailer Harness Dual Reverse Kit w/Diode Dynamics Lights IMG_2771
