barbersbbq
- First Name
- Paul
- Nov 18, 2020
- Augusta, GA
- 2021 F-150 Platinum
Did an update break CarPlay for anyone else recently?
Nope! Feeling sort of dumb. Thanks. I bet that fixes it! I love this siteAre you up to date on your iOS?
I just noticed the other day that mine started acting up as well after two months of seamless experience. Updated my iOS 2-3 days ago and everything works fine again. Hopefully it fixes yours.Nope! Feeling sort of dumb. Thanks. I bet that fixes it! I love this site
You need to forget all networks in your iPhoneMy Carplay forgets my phone every time I start the truck. I have to delete the truck out of my phone and do the initial pairing all over each time I start the tuck if I want the phone connected. Very annoying and this is just another Sync problem I have endured after waiting 4 months for the APIM to be replaced...
Master reset on the Sync seems to have fixed my problem. My Iphone now stays connected however I now get a message when I shut off the truck that the system is shutting down due to a low battery. Ford tested the battery and it tests ok. Just another anomaly/glitch with the Sync4.You need to forget all networks in your iPhone
That is an issue. They should try to relearn the BMS and also do a linbus initialization.Master reset on the Sync seems to have fixed my problem. My Iphone now stays connected however I now get a message when I shut off the truck that the system is shutting down due to a low battery. Ford tested the battery and it tests ok. Just another anomaly/glitch with the Sync4.
