Summer time - not updated automatically
Mr_Frenchy
Macan Turbo
Active Member
Eric
UK
Macan GTS 2017
Country flag
Last night, Clocks were turned forward by one hour (Summer time) and today my Macan did not update its time automatically :( - I had to go to settings / date & time and modify the time manually (note the update date/time automatically option was ticked).
The car was connected to GSM, Wifi signals and to my phone via Android Auto and some how, it was not able to update itself ...
did someone else face the same issue ?
JonoNZ
Macan Turbo
Well-Known Member
Auckland, New Zealand
Porsche Macan Turbo (MY25) BMW iX M60 (MY24), Abarth 500e (MY24)
Country flag
My Macan Turbo is the first car for many years that I have found does not correctly understand New Zealand summertime and adjust the time properly. I have had to change it to set manually.
nerv
Macan 4S
Active Member
Huy
BMW M3
Country flag
My car has not updated since daylight savings change. It’s still 1 hour behind🤪
wuls123
Macan 4S
UK
macan EV
Country flag
did someone else faced the same issue ?
Same here. If you switch off automatic, you will see there is no BST or daylight savings option for our American friends either.
so either the Porsche servers don’t have a proper time server or worse, it’s an omission from the PCM software…(I fear the latter, the former being an easier fix )
Diego
Macan 4
Well-Known Member
Diego
Italy
Macan 4
Country flag
Switched to manual this morning, set the correct time. Then switched to auto now and it works as it should. Same happened in October.
wuls123
Macan 4S
UK
macan EV
Country flag
Tried that - several times over the course of the morning - with no luck.
Diego
Macan 4
Well-Known Member
Diego
Italy
Macan 4
Country flag
I switched to manual at 6:30 this morning and changed back to auto at 11:40 so maybe it has to stay a while in the manual setting (however it's not the right or intended use of the "auto" setting....)
ferrocinque
Macan 4
Active Member
Francesco
Roma, Italy
Macan 4
Country flag
Mine did it automatically, 5 minutes after I started the car this morning. Since it has been in my garage, I think that first it had to lock the GPS signal (from which I think it gets the correct time).
nerv
Macan 4S
Active Member
Huy
BMW M3
Country flag
I’ll try this. I have it on manual right now. I’ll try automatic when I’m in my garage and give it a couple minutes.
QuiteBig
Macan 4S
UK
Macan electric 4S, BMW 440i, Mini Cooper electric
Country flag
Mine updated within seconds yesterday morning. I happened to notice because I had sent a route to the car, and I wondered why I was arriving an hour earlier than expected (it was only 8am, I was still half asleep), then it changed to an hour later almost immediately.
I was particularly sensitive to this exact point as my BMW never managed to update automatically despite it being ticked, and it used to annoy me more than it should do. A win for Porsche :)
CHpluto
Macan Turbo
New Member
Patrick
Switzerland
Macan EV Turbo
Country flag
I had to change manually. Then switched to auto...and I had winter time again.
hal1965
Macan Base
New Member
London
Macan EV
Country flag
I have another issue - I manually changed the time after the clocks changed to BST. The time on the instrument cluster display is one hour adrift from the time on the centre display. I have tried a reboot, re-setting the time but cannot get them to synchronise. Can be seen in this photo:
Electric Macan EV Summer time - not updated automatically SdC - 1
Does anyone have a fix?
Wivenhoe
Macan 4S
Well-Known Member
Bob
Wivenhoe999
Macan 4S
Country flag
Mine didn’t change automatically, despite being set for that. I then changed it manually. I got in this morning and set a destination and noticed it was reporting it was going to take me 1:10 to drive 4 miles. The dash clock and driving screen showed the correct time but the PCM was an hour out. I pulled over, turned off auto-change and then turned it back on and voila ! It then reported I would arrive in 10 mins.
