- First Name
- Adam
- Feb 15, 2022
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Occupation
- Drug Dealer of the LED World
We just received our Lightning not more then 12 hours ago and we've already developed the first BOLT ON reverse light kit for these new trucks.
The factory reverse lights are not that great, let's be honest (they honestly never are with most trucks). This kit comes with lights, brackets and wiring harness making it a breeze to get rear facing light setup on your truck! Everything you need in one kit. This kit is a 100% bolt-on kit that uses factory mounting points and factory wiring (your truck must be equipped with a towing package as this kit utilizes the tow package wiring harness behind the rear bumper).
The included KR Off-Road extension bracket allows the lights to hang from factory bolts under your truck. This bracket is made right here in the USA out of 11 gauge stainless steel (and powder coated black) ensuring a lifetime of durability.
Simply bolt on the lights under the bumper using the factory mounting points, disconnect the trailer plug behind your bumper, install the included quick connect harness and you're up and running!
QUICK TIP: You can alter the height of the Lights by flipping the Baja Designs mounting bracket upside down. This will bring the lights closer to your bumper or further away.
Included:
Available here: https://www.4x4truckleds.com/2022-ford-lightning-reverse-light-kit-w-baja-designs/
Included:
- 2x S1 or S2 Lights (Your Choice)
- 2x Vehicle Specific Mounting Hardware
- CrystaLux Wiring Harness
- Trailer Quick Connect Harness
