PopsGG
Gerardo
San Diego, CA
F150 Lightning Lariat ER
Details I got from the video:
2" level kit (no specifics mentions)
Tire: 295/60 R20 Nitto Recon Grappler A/T
Wheel: Gear Off Road 20 by 9, +18 offset
PopsGG
PopsGG
Gerardo
San Diego, CA
I cant be sure, but in the video it doesnt look like they trimmed the bumper. I couldn't see if the crash bar is still there.
Oh and in the video description they link to their level kit, its only $50. Would this cause any issues with the warrantee?
ExCivilian
'05 RAM 2500 5.9L Cummins; '22 Lariat ER
No. Also, it's not a lift kit so much as a leveling kit. It's only lifting the front 2" to make the front/rear of the truck sit level.
millim
Orange County
Lightning, P*2, XC90, 1964.5 Mustang,
Has anyone confirmed whether the leveling kit *actually* causes issues w/ Blue Cruise and/or adaptive cruise control? I realize it could theoretically do so given whatever calibration was done w/ the factory rake, but don't recall seeing anyone w/ Blue Cruise do this and/or speak to functionality after.
Stuff
So Cal
2022 F150 Lightning Lariat ER, 2024 Jeep Wrangler Rubicon 4xe
Someone who leveled mentioned blue cruise works fine... which makes sense because blue cruise works with a variety of weight in the bed/towing stuff which affects the height of the rear.
Looking for that post...
Here we go: https://www.f150lightningforum.com/...ift-leveling-1-7mi-kwh-after-100-miles.10997/
PopsGG
PopsGG
Gerardo
San Diego, CA
I have to imagine it works fine. Doing a leveling kit would have a similar effect on the truck as having a full payload because it would lower the rear end. There are no warnings against using blue cruise when the truck is loaded.
Also interesting to note is that even with different sized wheels the truck seems to still report accurate speeds...perhaps they are using GPS and not wheel rotation.
See here for confirmation:
webspoke
Stan
North TX
Lightning! F450, GT500
That combo looks good to me. The +18 offset would help reduce the chance of rubbing and trimming. The other truck posted recently had +0 offset wheels, about 3/4" more poke to cause clearance problems.
deserthi
Larry
San Antonio, Tx
2023 Ford Lightning Lariat
Tech
I don't think that Fox would approve or Horner the warranty for these coil overs on a lightning. The lightning is much heavier than a stock F150
