Nightshade
Nightshade
Aidan
Alberta, Canada
'22 Ford F-150 Lariat | '22 Ford F-350 S/D Tremor
Sup/t. Wildland Firefighter with Alberta Wildfire
I made this change and the upper light is super bright. No noticeable change to the lower light. Is there a way to change the brightness of the lower light or is this the way it is? Thanks
It should be brightened up a little but can be hard to see during the day, mine is really bright like the top led bar. See photo below. It’s probably because it’s during the day and it’s not really required if in DRL mode. But during the night, you’d really notice the difference. See my photo below.
Ford F-150 Lightning DRL LED Bar brightness boosted using Forscan 70BE6A61-D519-401E-8ED8-94E3078D4FF8
Bocephus
Bocephus
MI
2021 F150 XLT 302A 3.3L
Entertainer
Thanks - Do other drivers flash their lights at you? I'll have to see how others react to these lights. Will report back. Thanks
Nightshade
Nightshade
Aidan
Alberta, Canada
Thanks - Do other drivers flash their lights at you? I'll see have to see if others react to these lights. Will report back. Thanks
No problem! Nope, no issues with drivers on my end, but I do get a lot of questions on how I did it by 2021 F-150 owners. Was pretty cool to meet & talk with other F-150 owners about these new gen models. I know on the previous gen, Ford pushed a update to dim down the LED bar because it was blinding other drivers apparently, but no issues when I had my ‘16 and ‘20, both were bright just like this one. Personally looks better but definitely report back if you have had any issues. I’d love to hear.
JerseyGlock
Jimmy
New Jersey
2021 Lariat Powerboost
Is 2 the highest setting? BCM: 726-42-01 -> x2x2 - xxxx - xxxx
Nightshade
Nightshade
Aidan
Alberta, Canada
That line is to change in FORScan, this increases the LED bar on ALL settings, dial 2 on the exterior lighting mode just turns off the low beam headlights at night, if you wish not to use them, but the LED bar stays bright after the FORScan change.
DirtFreak
2003 Ford F250
Retired ( paper maker )
I have a question. By doing this will it cause the DRL's to burn out quicker ?
Nightshade
Nightshade
Aidan
Alberta, Canada
I’m not sure, seeing the DRL relies on the LED bar and not the low beams, I’ve yet to see a full LED headlight (even from 2015-2020) die off because of this. I used the same thing on my 2016 F-150 for years and the 2020 F-150 for a few months like this with the low beams off at night (except on highways), zero issues.
Nightshade
Nightshade
Aidan
Alberta, Canada
great mod to blind oncoming traffic..
Haven’t had any issues since I owned a 2016 & 2020, both had oem LED bars on the headlights. Same with my 2021. Zero issues and zero flash from oncoming but a few asked how to do the same on theirs lol, they wanted it too. Come to think of it, haven’t had anyone I know here in Canada that ever had any issues at all.
Hebed118
Louisiana
2021 Lariat Sport PB 4x4
Where can I find what needs to be changed to keep the rear taillights
Forscan can enable your rear DRLs to be on with the front ones. I did that for mine for an even look after boosting the brightness.
Where can I find out how to do this? The spreadsheet doesn't seem to mention it.
Nightshade
Nightshade
Aidan
Alberta, Canada
What specifically are you wanting to do?
Californiacarver
Nor Cal
2021 F150
Ok new to forscan. Was able to edit a few other changes. But this Brighter DRL I wasn't able to accomplish not sure what I doing wrong.
Nightshade
Nightshade
Aidan
Alberta, Canada
Did you change the “2”s that are in that line? Make sure you’re using BCM (As-Built), scroll down until you find line 726-42-01. Then the as-built numbers in that line, just change the numbers where the “_” is on the line, that’s it. Don’t write the complete line and do not change anything that is in place of the “x”. (do not write the “x”s).
