separating front tweeters
CarbonizedRCSB
Todd
St.Louis
2021 F-150 5.0L RCSB Carbonized Gray
Does anyone know if the tweeters are still ran with the door speakers in a regular cab? I'm trying to run the Kicker Key 200.4 in bi-amp mode to have active front stage. If I ran new wire for the tweeters, where would I hook them up at?
Jesse-Infotainment
2021 F150
Yes, they are ran together. You would be best off to just separate at the A pillar. They are joined in the door connector.
Pull the a pillar off, cut and add your wire.
Millionvill3
James
2021 f150
Business owner
do you know where the crossover is located?
CarbonizedRCSB
CarbonizedRCSB
Todd
St.Louis
It makes more sense after putting it all on paper, I think I was just overthinking it. Since I have to run the tweeters on CH-1, wouldn't it be easier if I just use the same wire and then re-run the fronts to the RL & RR?
Jesse-Infotainment
2021 F150
If i were you I would use all the existing wiring and just separate the tweeter. No reason to try and run through door connectors. Run new wire only to the tweeter.
