Rear dashcam cable routing
sbi
Upstate SC
2021 F-150 5.0 Lariat SCREW Space White
I have a 2-channel Viofo. Main camera was a no brainer, I used a mirror plug, quick and easy, no need to run anything behind trims and pannels.
I started setting up my rear camera, took the rear door seal off and wanted to simply tuck the USB cable in the ceiling, but then I saw the airbag/s running along the vehicle and they are attached to the roof, so there is no way to bring the cable behind the airbag without taking the ceiling off, which of course I am not going to do.
Nor am I going to put anything in front of any airbag.
My quesiton is - did anyone run a rear camera cable up to the front and have some suggestion or input as to how/where to run it without taking the entire vehicle apart?
Thanks,
SILVERBULLET69
Missouri
YOUR GLOVE BOX LIGHT IS ON
My wife got me a dash cam for christmas. Could you define a "mirror plug".
thanks
Sapphire
Chicago
2021 F-150 Powerboost Platinum
SILVERBULLET69
Missouri
Thanks fellas found one at Dongar tech. Also might add you need an adapter for your particular power supply from the 16 pin usb mirror. 2 diff items same company.
Reactions: sbi
Skier167
Nate
Ohio
2016 f150
I ran mine down the passenger side of the truck below the door sill trims. I removed the two sill plates and the passenger footwell cover. That gives you enough access to run the wire all the way down to behind the rear passenger seat.
Ford F-150 Lightning Rear dashcam cable routing 1640705534304
Ford F-150 Lightning Rear dashcam cable routing 1640705480566
Reactions: sbi
sbi
Upstate SC
BTW - found an excellent video for wiring rear-facing dash cam without interfering with the airbags. Very detailed.
JerseyGlock
Jimmy
New Jersey
2021 Lariat Powerboost
Why bother running a cable. I simply installed a 2nd rear camera.
JerseyGlock
Jimmy
New Jersey
Which is operated by a battery, or USB cable?! ?
I have a 12v via cigarette connector version. There are USB versions out there. Trick is aim the camera towards the tailgate, add spacers if you are mounting on the glass.
DBL R
Jarred
Washington
2021 F150 powerboost
PA
For my rear camera I ran the cord along the interior/molding along the driver side. Mounted the camera on the drivers side rear glass, so the auto opening window doesn’t hit the camera.
Required zero removing of trim pieces. I was able to feed the wire into the door molding with just my finger.
sbi
Upstate SC
Right, and where are you getting your 12v for the camera from?
sbi
Upstate SC
That means that your wire is in front of your air bags, not behind it. This could potentially interfear with your air bag.
JerseyGlock
Jimmy
New Jersey
OK, so did you not run a cable from the rear camera? You still needed to run a cable, at least to the rear cigarette socket.
I have 2 units. Rear camera is independent from front camera.
