Zyvin
Yea, I didn’t even try the old black package versions, because they said the 2021 front camera is different than the 2020’s and mounts differently in the emblem.I did mine today.
Heat up the outside real good with a heat gun. There isn’t a lot of the sticky tape actually holding the emblem on, it’s more for keeping water out.
Anyway, heated it up pretty good from the outside, then took the flat edge of a pry bar and pushed on the plastic nipple on the left side of the emblem until it popped out of the bed. There were no huts on the plastic nipples, for mine.
Then I closed the tailgate, wedged my fingers under the emblem and pulled it right off. Didn’t break the emblem at all. wiped the surface down with rubbing alcohol and pressed the new one into place.
The front emblem was a bitch.
Also now the 360 camera isn’t lined up so I need to get it calibrated.
