Installing Ford's HomeLink in a XLT.
ProperCrab
Walt
Houston
Tahoe, 14th Gen on order
Commercial Project Estimator
Who'd you order it through? I ordered from Kia.Parts on the 15th shipped the 17th and delivered on the 22nd. If you ordered it through Kia you need to respond to their email confirm your vin OR tell them it fits your application and your not using it on Kia.
No, you have to use the line taps provided in the kit from Kia. It's as simple as plug and play tho. Some people on the 14th gen FB group have modified the two harnesses to make it plug and play.
Quickparts.com but I emailed them and now have tracking into and should be here 1/6.
Missmy3/4ton
Midwest
300a XLT 5.0 4x4
Can I trouble you for a pic? Just super curious on if it looks out of place. Thanks man
Nah, it looks great. Even better than Fords, imo, because it's more rounded/ squared off.
Here's a link to a write up someone did, took me all of 15 minutes including programing to do.
Here's the same photo incase the FB post doesn't load for someone. Top is the Kia, bottom is Ford
Ford F-150 Lightning Installing Ford's HomeLink in a XLT. 267851870_4948648341826281_3035857038734299521_n
jj4567
United States
2022 F-150
Night auto-dimming still work?
Missmy3/4ton
Midwest
300a XLT 5.0 4x4
Thinking of adding this to my new F150 XLT. I put one in a Toyota Tacoma years ago. Got it from here - https://www.bobsmirrors.com/Gentex-Auto-Dim-Mirror-wHomelink®V4-Plug-Play-For-Select-2010-2022-Ford-Vehicles_p_353.html
I mean is an $140 is worth the 'plug and play' aspect? Otherwise, the mirrors are nearly identical. Looks like the removed the compass from the kia and added a separate button for something, auto dim on and off? (vs just one on/off button)?
https.j0n
Jon
Ontario, Canada
2038 F150 XLT (ordered in 2021)
Would you be able to copy that write up here? The FB link doesn't work.
parkerdog
forgottonia
22 f150 XLT RCSB
When you say programming, you just mean the mirror itself for the garage openers or does it have to be set with forscan?
Missmy3/4ton
Midwest
300a XLT 5.0 4x4
Looks like you have to be signed in to FB and in the group, sorry about that.
Ford F-150 Lightning Installing Ford's HomeLink in a XLT. 267583973_4948648561826259_2564257309193344068_n
Ford F-150 Lightning Installing Ford's HomeLink in a XLT. 267402512_4948648958492886_8318354594129573895_n
Ford F-150 Lightning Installing Ford's HomeLink in a XLT. 268034886_4948649155159533_6550703234147985548_n
Just that it need to be programmed to the garage door. It's as simple as pushing a few button.
https.j0n
Jon
Ontario, Canada
Easy day. What’s the fb group if you don’t mind sharing.
Missmy3/4ton
Midwest
300a XLT 5.0 4x4
The one linked above is "2021+ Ford F-150" (click the little F in the top corner). There is also a "14th gen f150" group that's decent as well
parkerdog
forgottonia
22 f150 XLT RCSB
Is there anything you could copy and paste to me in a conversation or on here if allowed? I'm not on facebook. (basically anti-social)
I'm guessing the thing that says set aside if dropped is the camera?
Missmy3/4ton
Midwest
300a XLT 5.0 4x4
Nah, all of the comments are either; thanks installed it was easy, how do you pop the covers off, or poor 'pheasants,' should have got a loaded lariat.
Im not following, sorry. You do have to remove the cover which as the lane keeping camera in it.
parkerdog
forgottonia
22 f150 XLT RCSB
You can read sticker on the camera in the one pic. It says if dropped set aside . Must be really fragile. Thanks for getting back. Looks like they are on backorder now. Everyone thinks it's a good idea.
Missmy3/4ton
Midwest
300a XLT 5.0 4x4
