Charging voltage
Bassjammz
Jeremy
Ohio
2021 f150
I could not find a clear answer but what is the voltage that the f150 charges at. I know it is a range and best I can find is 13.1 - 14.5
tbinmd
18 KR F150
The voltage is variable. I hooked up a blue tooth voltage monitor to my battery that logs the voltage. Highest I've seen is 14.74 volts. But seems to hover around 14.6 when the engine is running.
Bassjammz
Jeremy
Ohio
2021 f150
What monitor did you use
tbinmd
18 KR F150
Gros Ventre
Western Wyoming
Powerboost
The battery in the F-150 is an AGM (Absorbed Gass Mat) battery. As best I can determine they operate a bit differently. I had occasion to swap mine out. Usinge a voltmeter it appears to operate at a constant 12.6 VDC. Even though I charged the new one up to a level above 13.2 on the charger, once I installed it and ran the engine it drifted back down to a steady state 12.6VDC.
