Griswold22
Gilles
Shannon
smart EQ, Honda Pilot
Thanks for those insights !
Come September, I should be able to share my experience towing a 20’ Geo Pro similar to the one on your last photo. I’m hoping to reach 125 miles (200km) with a trailer about half the weight of your Airstream.
Carrying a 7 500 watts dual fuel generator on longer trips and hard to reach destinations (longer interval or no charging stations), I plan on running the trailers AC with the truck at night when dry camping and charge the truck with the generator during the day.
Have you tried running the AC with the truck ?
oneguynick
oneguynick
Nicholas
Standish, MI
F150 Lightning Platinum
CTO
I did, and it functions fine. I have a slow starter on our AC that allows it to run on a standard 20amp house plug, so it's probably not the best example.
My FIL has a 20' Geo Pro, and his hit to the gas mileage of our ICE F-150 is about the same as the airstream. Sure you will be fine depending on the terrain.
2wheeltraveler
Austin, TX
2022 F150 Lightning Lariat Rapid Red
Not long after mine arrives, I'll be putting it to the test with a 32' Grand Design Imagine 3400BH.... will be close to max load and not the slightest bit aerodynamic. My ICE GMC sees about 50% of the expected range.
Griddlez
Griddlez
Metro-East of St. Louis, MO
Looking forward to hearing the results! Please share when the time comes.
Kev12345
Ram 1500
But I read on the internet that the lightning runs out of juice after 60 miles! :ROFLMAO:
Seriously though these trucks clearly need more range for towing...
bri0528
Novi MI
2022 Bronco, 2020 Explorer
Be careful, the owners manual advises against using BlueCruise with a trailer:
Ford F-150 Lightning 300 Mile Trip to Frankfort with the Lightning - Thoughts and Stats with the Airstream in tow 1655821331415
FordLightningMan
Upstate New York
F150
I have a SR coming and I don't intend to tow much, but this info would indicate you'll get about 70 miles per charge with a SR.
The current administration is working to mandate charging stations every 50 miles on interstates, so it could be possible to tow a trailer even with a SR. Depending how far your camp site is from your house, you certainly will need to add a few hours to the trip. At a minimum, campgrounds will need to start adding Level 2 chargers, which would mean you could camp anywhere that's < 70 miles from an interstate. Though it's not the interstate that scares me going forward, it's the challenges you might run into if your destination is a rural area a few hours off of the interstate.
Mathington
Mach-E SR AWD
Great write up! I love seeing the the details about journeys like this and figuring out the true capabilities of the truck.
LYFISHER
new york
F-150 Lightening Lariat Extended Range
Great write up. Thanks! I went back and forth between F150 EV and 8-cyclinder ICE (6.5 box, 6 seater, the 8-cyclinder ICE is for towing with 36 gal tank). Glad to know EV RV towing is doable, though must be planned carefully.
I don't like the shorter box and the huge fixed center console, but it's a small price to pay for an EV.
bigskylightning
Montana
2023 F150 Lightning Lariat (Extended Range)
I REALLY appreciate you taking the time to report. We're considering selling our 25ft Safari Airstream for a lighter trailer - we haven't pulled it yet anywhere, but we have a similar truck (2023 Lariat Lightning) and, presumably, range. I'll keep a look out for a similar report with a trailer like the ones we're considering for a final decision.
