Tenetke
So I had plans to change the way the Lightning looked with a new set of wheels and tonneau cover.
I swapped out the factory Platinum wheels for some Y spoke 22’s.
I also had to have tint on the front and went with ceramic window tint from Xpel.
I added a bed rug impact full bed liner and and Retrax Power Pro XR cover.
Also, I changed my antenna to a shorter flexible antenna.
If they make a kit for an adjustable air bag kit I plan to do that as well.
More info:
Kalon Kolossus 101 Alloys wheels
Gloss Black
22X9 with a +30mm offset.
38 or 39lbs.
The xl load tires I’m planning on getting are 37lbs. I believe they’re $250 a wheel. 76-77lbs total was pretty good I thought.
Bed rug was a perfect fit. The installer said he cut to fit the pro power onboard but he has also done that for ICE F-150’s also. So it was the same install for him. He said the cover was the same install but the wiring was different because of the different power source than an ICE truck.
More info:
Gloss Black
38 or 39lbs.
