No EVGo Chargers. I attached a couple more pictures of the chargers and the error messages I've gotten. I tried resetting the chargers, bur no luck.There is an OBCC update available for Lightnings. That module controls charging.
If you DM me your VIN I'll check and see if it's in your update list, pretty sure though that everybody is supposed to get that. Dealer tech will do for free. Warranty.
Also, was this at an EVGo Fatboy charger by any chance?
Best,
the error about stopping providing backup power makes me think even more there’s a power issue at the charger. Maybe it starts charging, loses power, intelligent backup tries to kick in, can’t since the Bosch isn’t made for that, ends the charging sessionNo EVGo Chargers. I attached a couple more pictures of the chargers and the error messages I've gotten. I tried resetting the chargers, bur no luck.I plan on testing on another public charger this evening to see if I have the same issues. A combination of "Charge Fault" and "Vehicle Fault" error messages? I'm likely going to have to reach out to Ford and my dealer to see what's going on.
That is extremely weird.All the other EVs would never know the difference since they can’t do bidirectional power
I doubt it. The protocol is pretty sturdy and requires stability to enter charging mode. What I think is happening is that the truck's manipulation of the pilot signal is confusing the charging station, and in turn it is disconnecting and erroring in the truck.Makes me wonder if those older EVSEs need a shot of dielectric grease. Maybe the inital handshake is fine, just maintaining it is an issue.
Not necessarily, could be a joint thing... that EVSE may be less tolerant of voltage issues *and* the truck may be out-of-tolerance on its resistance to activate the charger. That would allow most chargers to work with his truck, and other vehicles to work with that EVSE, but the two combined will have problems. You'd need some equipment to watch the pilot signal to see what's happening to cause the problem.Bottom line it's the EVSE that's the problem here and not the truck. At least that's what I'm getting out of this. Especially if his portable equipment is working without issues.
Understood but somebody who can see his DTCs needs to use their decoder ring to get a clue and advise further. That means at the very least a call to the service advisor who can pull up his VIN in PTS and cypher it out.Not necessarily, could be a joint thing... that EVSE may be less tolerant of voltage issues *and* the truck may be out-of-tolerance on its resistance to activate the charger. That would allow most chargers to work with his truck, and other vehicles to work with that EVSE, but the two combined will have problems. You'd need some equipment to watch the pilot signal to see what's happening to cause the problem.
Ok, latest update. I spoke with Ford about the issue. After being transferred to 3 different “charge pro” departments they ultimately told me to take back into the dealer to have a diagnostic. I called my dealer and going to take the truck in once they have some availability.Has anyone had any issues with charging their truck at a public charger? My mobile charger works fine when I plug in at home, but when I tried charging at a level 2 charger at work, I'm getting the solid amber lights on the charge indicator next to the charge port and an error message that there is a "Vehicle charging fault"? Simultaneously, I'm getting a "Service vehicle soon" message as well, but this disappears once I stop trying to charge at this particular charger. Has anyone run into this issue or has any ideas on what's causing this issue? I'm hoping someone might have ideas on how to troubleshoot?
So it seems there's some type of an incompatibility between the Lightning, TeslaTap, and Tesla gen 1 HPWC unit. My TeslaTap works with my HPWC gen2 charging the Lightning (delivered today!), but does not work with the gen1 HPWC. When I plug the TeslaTap into the gen1 HPWC it stays green, but when I plug into the Lightning the HPWC flashes red 8 times and refuses to charge.Interesting. My TeslaTap is an 80A Mini, and I see exactly the same symptom on the Gen1 charger that you described.
I also have an 80A JDapter Stub which I leave on one of my 2 gen2 chargers at home - and it occurs to me that because the JDapter is sitting right there, I may not have tried the TT since I rewired the gen2 units' branch circuit and upped them from 56A to 80A. I'll try it when I'm home later this week and see what happens. At 56A the TTMini worked fine on the Gen2 units.
