Aminorjourney
Having driven some 1500 miles in two days, we used quite a lot of BlueCruise on I84 and wow it reduces stress!
The only big issue is if you're heading into low sun at the end of the day - then the truck gets a little nervous about going hands-free (but still does the majority of work. You just have to hold the wheel!).
However, on our second day after a charging stop, BlueCruise refused to turn on. It would activate as per normal, and display the little bubble around the truck. The screen turned blue, but when you took your hands off the wheel it would nag to put them immediately back on. Even though there was minimal glare (so we know that wasn't the reason), the truck just point blank refused to cooperate. It would steer as if it was on blue cruise, but didn't want to let you take your hands off the wheel despite conditions being met.
Note: this happened for the best part of 180 miles, and we'd driven the other way on the same road with no issues... And the sun was behind us (so no issues there).
We pulled over a few times to reboot/turn off the truck and start again, but the symptoms persisted. No matter what, the truck would not activate BlueCruise.
At our next charging stop, we disconnected the 12V battery for 30 seconds and then reconnected before charging the truck. After our charge stop, everything was back to normal!
Just thought I'd share in case other people have the same issue!
Nikki.
Nikki.
