Why no auxillary input on Sync 4 system?
Doggy-Dog
Ted
Western Michigan
2018 Pacifica Limited & 2021 Loaded Lariat
Is there any good reason why Ford did not add an auxiliary input on the sync 4 system. It would be nice to play some of my CDs in my old portable player. Can only do that in the Pacifica. It has an aux input.
dhrandy
Randy
Concord, NC
1950 Plymouth, 2021 F-150 Lariat 500a
Engineering Tech
You can also rip whatever cds to your phone and listen to them. Does the F-150 support USB stick playback? If so, rip them to a stick and play them.
dhrandy
Randy
Concord, NC
Engineering Tech
JerseyGlock
Jimmy
New Jersey
2021 Lariat Powerboost
USB port in front of the the shifter supports audio input. Not sure about USB port inside the center compartment.
Bryan Simon
Bryan
San Antonio, Texas
65 Ranchero, 66 ElCamino, 05 Ranger, and more
Maintenance
USB inside console, in the back of the console and on the dash are “charge only”
Data ports are in the front of th console or lower center on bench seat trucks
AutonomousHybridF150
Kristopher
Pensacola Fl
2021 F150 Powerboost
Adjuster
I know right!!!
Total first world problems, but I am a little flustered that I can’t play true high resolution audio in my truck. Would have been a nice sound stage :(
Bought the DAC and can’t even use it in my truck, after I looked for the port.
What is it with Ford and them hating on the 12 volt outlets and line in analog audio ports?
Jerry Can
Calgary
2021 F150 KR Powerboost, 2-tone Rapid Red, 157”
Fuel Container
I too am disappointed that I can no longer use my preferred DAC with this truck. However, I can still play high res audio through CarPlay fortunately.
Doggy-Dog
Doggy-Dog
Ted
Western Michigan
Yes, I can put them on a stick but the time spent doing so is a drag when Ford could have added the Aux like Chrysler did.
Thanks for the comments and info on working and not working inputs on the truck. I guess it will be something to mess with when I find some time.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
Would be cool if you guys could find some kind of DAC to HD-FM transmitter and then pick it up on the HD tuner in Sync4. At least that would cut out the middle man of ripping into compressed (but large for best quality) files or using a BT transmitter, which could be just basic SBC encoding.
Lippy
CA
2021 F-150 Powerboost
I don't think that's true. I believe the max rate for CarPlay (including wireless) for now is 16-bit/44.1 kHz
Jerry Can
Calgary
Fuel Container
I was not aware of that, but at least it’s still CD quality.
Doggy-Dog
Doggy-Dog
Ted
Western Michigan
I gave it a try with an old and low Mb drive. It worked very well. Except I could not get a full CD on that old relic. So I got a big Gb drive and it has also worked very well. Maybe this Winter when I go inside to avoid the white crap I will find more time to rip more CDs.
I ONLY listen via USB now,
it's just so darn easy and convenient - one for each vehicle
tho I have hundreds of cassettes
tens of Albums
and even more 'CD's
