F150ROD
Put a wireless charger option on the center console organizer, right where it says Lightningwe will start to work on the Front Grill, it will take some time to finsih. anything else we shall make?
Product suggestion: A replacement cover for the 12 volt battery compartment on the back wall of the frunk. The attachment brackets on the back side of the cover are already broken on mine. I just ordered the center console tray.Hi, dear F150 lightning forum Admin and Owners,
This is Zac from BestEvMod (also known as AOSK), we are an experienced aftermarket accessories developer, we had made all kinds of exterior & interior accessories for Mustang Mach E, Tesla Model Y, Ioniq 5, and etc...
What we are able to make?
We make all kinds of exterior and interior products! for example, Floor mats, interior trim cover, mud flaps, body kits, console organizers, and other products according to each vehicle's specific need.
Or check us out at our website www.amazon.com/bestevmod
Why we are here?
We are starting our new product line on the F150 lightning, and we want to discover what kinds of products are needed by F150 lightning owners specifically. And most importantly, build up an efficient communication channel between us and owners, back our products, and make sure owners that purchase our product will have a great experience.
For example, on our Mach E product line, we stay active in the Mach E forum, and owners discuss what kinds of products they would love to see on their car, if we are capable to make them, then we will make it happen! (Owners in Mach E Forum told us they want to remove the front door handle, and we make a kit for it!)
What we had made or making for F150 lightning?
Console Organizer
We mix the classic design of F150 on the leather mat of this console organizer
Screen Protector compatible with F150 Lightning & Mach E
Coming Soon!
A Metal Volume Knob Cover that better matches the toughness of the F150 Lightning!
Change the original plastic feeling on the volume knob to a metal one.
What is Next?
Need your help here, Please share your product ideas with us, if we are capable of making them, we could make it happen!
What kinds of products do you really wish to exist on your F150 Lightning? share with us, let's make the drive with the F150 lightning even better!
Thank you
I posted my Frunk button cover in this form. https://www.f150lightningforum.com/forum/threads/frunk-button-cover.12228/#post-262592Clean Fog Light Solution without messing with aerodynamics
Mud flaps, specifically fit to the Lightning.
Front Light Bar mods: precut tint, Light bar replacement (either for Pro users, or an RGB mode)
Custom inside Frunk Button Cover
Mesh/Grill Insert in front of front active shutters (below frunk)
If one can get the drawing specs. one should be able to 3D print a modified front grill.we will start to work on the Front Grill, it will take some time to finsih. anything else we shall make?
Hi dear Owner,Product suggestion: A replacement cover for the 12 volt battery compartment on the back wall of the frunk. The attachment brackets on the back side of the cover are already broken on mine. I just ordered the center console tray.
3d print a front grille might be quite expensive. but a direct cover on top of the current plastic feeling could be an applicable solutionIf one can get the drawing specs. one should be able to 3D print a modified front grill.
May i know why we need a mesh/grill insert in front of the front active shutters? so we could know how we should work on it.Clean Fog Light Solution without messing with aerodynamics
indeed, we usually keep our floor mat product without any logoI would love some floor mats with the Lightning Logo, but I know that is out of your usual type of product.
Bed cover solar charger system.we will start to work on the Front Grill, it will take some time to finsih. anything else we shall make?
Thanks for these info, we will bring this to the team. some of them could be hard for us at this point, since our own F150 lighting havent arrive yet.Replacement for center arm rest with fold out table. Pro models do not have the table option, so those folks would go for it. Beyond that, I would like the arm rest to have internal storage or pockets, plus for a better table surface with indentations for cups, pens, cell phones. A pen groove all the way around would be good to prevent things rolling off! The center arm rest just seems like a waste of good storage space, but need to keep it comfortable. Not sure how it can be removed and replaced, hope it is not impossible. Retail up to $200?
The rear seats on the Pro and XLT models do not have the center seat cupholders. Amazon has some options but I think there is room for more choices. Maybe a good place to keep an extensive first aid kit? Up to $100?
And for Pro and XLT models, a very high quality LED rear light bar (below tailgate unless there is a way to seamlessly add to tailgate surface) with reverse and signal lights. Seems the ones on the market are not lasting very long. Up to $200?
I hope these items are within your capabilities!
WOW, I have to say this is a great idea, I would want one personally. but unfortunately, this is definitely out of our expertiseBed cover solar charger system.
Not my topic, but I'll help. The lower grill insert would be for strength, to keep road debris from entering cavity and damaging the active shutters.May i know why we need a mesh/grill insert in front of the front active shutters? so we could know how we should work on it.
frunk button is interesting, how would you want it to looks like?
I don't think metal is necessary. I have attached 3 photos of the back side of the cover. My failure, and others reported, occurred at the tab at the top on the driver's side (or top right looking in the frunk). Photo 5231 shows a "normal" tab, although you can see the beginnings of a failure at the white spots on top of the "fins". Photo 5232 shows a failed tab with failure at the top of the fins. It would be easy to tear this tab away from the fins by hand. This is obviously a deficient design. One option could be to alter the design to fill the area between the 4 fins with solid plastic to provide more surface in contact with the tab.Hi dear Owner,
I also saw some info about this around, we could try to work on one.
our concern is that, if we use ABS material, and same thick as the current one, it might be fragile as well, if we want to add some strength on it, it might be too thick and not flush with the frunk.
Shall we look for a metal option?
