Sezary
- Feb 8, 2022
- Kathleen, GA
- Hyundai Ioniq
My wife and family moved to Vegas for work and took the lightening (Lariat ER) and our second car(Tiguan) across the country.
We drove South to Destin to visit friends and family so we took I-10 all the way to Phoenix then hitting HW-60 to 93 to Kingman and then to Vegas using the trip planner in the Ford Pass app and ABRP for cross check with Plug Share to see the health and state of the EA chargers.
Leg 1: ATL to Destin
No issues with the network or charging along the way.
Leg 2: Destin to Lafayette
EA only had 1 charge location in Pensacola, this was my first time having an issue with EA since taking delivery of the truck. The EA station locked out and the cable got stuck in the lighting. I used the manual disconnect pulley inside the frunk and called EA. I had to charge there to start our leg so that added about an extra 2 hours.
Lessons learned, if plug and charge doesnāt work activate the charger from the Ford Pass App, no dice? Activate from the EA App. No dice? Hail Mary to EA tech help line. If I had checked Plug share I would have seen the issues at the station ahead of time and could have planned to avoid this
Leg 3: Lafayette to San Antonio
Averaging around 1.8kw going 65-70ish, 1.4-1.6kw when doing 80mph trying to keep up with the wife. No issues with charging.
Leg 4: San Antonio to Van Horn
If you find yourself in Van Horn eat at Moms kitchen.
Leg 5: Van Horn to Phoenix.
The cold weather hit us the morning we left. My range at 80% dropped to about 170mi from 250mi. None issue, trip planned added one additional charging stop. I will say today I started charging to 80% regardless of what trip planner said. Not due to weather or driving habits but with three kids charging for 18 minutes or from 23-67% wasnāt enough time to get out and change diapers and stretch legs.
Leg 6: Phoenix to Las Vegas
I do NOT recommend HW-63 to 93 to Kingman from Phoenix. There is only one charger between PHX and Kingman in Wickenburg at a Ford Dealership that is broken a capped at 22kw. This was my first non-EA charger I was routed too. I figured it being at a Ford Dealership it would be fine but it was an AWEFUL POS. Plug share did mention this but avoid this charger at all costs unless you must use it. I donāt know how Jones Ford of Wickenburg can be EV certified because their 1 charger is atrocious.
This drive already stretched the trucks range to its limit due to below freezing weather and I rolled into Kingman with single digit range.
Overall thoughts:
EA network worked fine, but not the reliability I expected to see. Ford Pass Trip planner was rock solid and minus the 1 non-EA charger was always within 1% of the estimated charge state rolling up to EA chargers. Speaking of charging, I do not know what it is with VW I.D 4 driversā¦.but they love to take 350kw stallsā¦that they canāt fully useā¦.and charge to 100%
. Nearly every single time I rolled up to a EA station some ID 4 is sitting there charging at 74kw to 118kw (max)on a 350 stall.
edit 1; corrected I-5 to I-10
Overall thoughts:
