Bandit216
Bandit216
Alaska
Mach E GTPE, Lightning Lariat
...I think Ford underestimated the knowledge level, determination, and skill of some future owners.
And over-estimated the knowledge level and skill of others.
Gimme_my_MME
But will you be able to designate whether a destination is a charging location, or will it only work automatically for the Ford Network chargers? I've found there are many DC fast chargers out there that are not shown when you are searching Sync nav for the nearest charger - either they are too new or they are not part of the Ford network
Very valid point, however initially it will only work if the destination is navigated to via the Ford Sync Navigation. So it will not be toggleable but should work even if it isn't part of the Ford charging network but it knows it is a charger
meow
2022 Lightning Lariat ER; 2024 Hyundai Ioniq 5 SEL
That's... dumb.
More configuration buttons/options. They don't even need to physically add more to the truck because of the infernal touchscreen!
Let's have an advanced mode 🤣
vandy1981
Tennessee
Plumber
Impressive post. Thanks for sharing!
How on Earth do you keep the truck so clean in the dead of winter?
Bandit216
Bandit216
Alaska
It's easy. You wash the vehicle just after the first snowfall in October and, since the snow doesn't melt until April, it stays clean. (Also, they don't use salt on the road to melt the ice because it doesn't work.)
vandy1981
Tennessee
Plumber
EVben
Ben
MN
Lightning, Ranger
Ha, I had the pleasure of living a couple years in Fairbanks after growing up in MN. Seemed instead of salt, everyone just has a cracked windshield from the gravel. Fantastic pictures and report!
PungoteagueDave
The windshield cracks aren’t normally from gravel. They are usually spontaneous cracks due to the extreme cold and temperature disparity between exterior and interior. Manufacturers do not build or test for these extremes. You’ll see the same phenomenon in Montana and Wyoming’s higher elevations where temps are routinely 20 degrees or more below zero for extended periods - nearly every truck has a cracked windshield - and no point in repair - folks I know out there see the crack as the point of reduced stress and a necessary step in owning a new truck.
EVben
Ben
MN
Lightning, Ranger
Interesting, I didn’t know that, had always just assumed it was the roads, the more you know.
