Ajjra
Realizing that if range is a priority, this is probably not a go-to MOD, but since someone’s going to ask, it might as well be me: have you had an opportunity to measure the impact on range from these changes?
Sure! Anything specific you are wondering about?This looks really nice! Could you say more about the wheels/tires and clearance?
* Even when the truck was bone stock, I never had a great consistent experience with Blue Cruise. It always seemed to wander in the lanes. After the Wheels and tires (before bumpers) it was about the same bouncing between-the-lanes effect maybe a touch worse on some roads. Bumpers did not seem to make a difference either way. Overall my experience with it makes me believe it's more affected by road conditions (lines, turns, on-ramps, off-ramps etc) than the lift or bumpers.I see that these bumpers anticipate sensor relocation (eg from the old bumpers into the new) - though presumably at slightly different locations/angles. Looks like as many as 10 sensors are implicated (4 in back, 6 up front)
Two questions:
• any feedback on resulting sensor performance? Blue cruise being finicky as is, and assuming these sensors play a role, interested in effects
• if bumpers are being customer-installed, are there special instructions regarding dealing with the sensors?
I assume the tires are the standard 12.5x35R20. What offset are the wheels? Something pretty positive I assume. Is there enough clearance to accommodate a more neutral offset?Sure! Anything specific you are wondering about?
I like the grille as well. Would like to see it sold too.Love it !
the front grille with the matching body paint is the way Ford should have designed it in the first place, imho.
do you sell the grille as a stand-alone?
The crash bars will need to be cut for the bumper to fit@SinisterEV do you have to trim the crash bars?
