Attention all truck enthusiasts!
Looking to level up your truck's style and functionality? Our running boards are the answer, and we're ready to give you unbeatable discounts to make it happen. This month we are showcasing the Aries AdvantEDGE, Aries RidgeStep, Raptor 5" Black Slide Track, Westin HDX, and the Magnum RT 2 steps!
Aries Black AdvantEDGE running boards feature an aluminum 5.5" wide octagonal tube construction with die-cast aluminum end caps and come in a carbide black powder coat finish. The aluminum construction makes these running boards strong, lightweight, and impervious to rust and corrosion. These boards feature a stamped aluminum tread plate that provides a non-slip stepping area that will provide a safe step in and out of your vehicle. Aries has incorporated a track system to allow for easy mounting with their custom, vehicle-specific brackets that come included. They bolt onto your truck without any drilling or special tools. Aries backs all of their AdvantEDGE truck accessories with a five-year warranty.
The Aries RidgeStep running boards are rugged and tough which compliments any work truck perfectly, and they look great too. Made to handle the roughest and worst work conditions you can put them through. RidgeStep running boards are commercial grade steel with a stamped, non-skid tread area that is 6.5" wide. There are no plastic parts to crack or break on these running boards.A black textured powder coat finish will help your new side steps withstand scratches, grime, and rust. Aries RidgeStep running boards use custom mounting brackets that come with the boards to give you a quick and easy installation.
The Raptor 5" Black Slide Track Oval steps are made from corrosion resistant aluminum, making them an excellent choice for those that live in coastal climates and areas where the roads are heavily salted in the winter. A sleek, textured black powder coat and stylish angled endcaps add further protection from the elements and look great on any vehicle! These cab-length steps are 5" wide and fitted with a non-slip step pad, which makes for plenty of room to safely step up to or down from your vehicle. Raptor backs these steps with a limited lifetime warranty on materials and craftsmanship, and 10 years on the powder-coating.
The Westin HDX Drop Steps have a 4" wide die stamped step area to achieve optimal grip. This provides confidence any time of year when entering or exiting your vehicle. The die stamped step plate is removable with a solid surface underneath. This makes it easy to clean and also keeps dirt, mud, and snow from getting inside the bar. With fully welded endcaps, Westin's HDX Drop Steps look seamless and keep the elements out of the bar. These drop steps feature an angular design with a lowered step that lives up to its name. This allows you to get in and out of your truck no matter the height of your ride. The Westin HDX Black Drop Steps come with all hardware required for installation, so you can be confident while buying that you'll have a smooth, easy install that'll be rolling down the road in no time.
The Magnum RT Gen 2 patented angular design is as functional as it is aggressive looking. The step plates have raised slots that provide excellent traction for a safe step every time. The first drop step to really get it right was the Magnum RT Steps, which have been a staple for many truck owners for many years now. Magnum RT Steps have just been upgraded with a second generation that features a 4" wide step plate that is 30% longer than the 1st gen at a whopping 16" long! The sturdy 14-gauge steel-built steps are going to resist any corrosion thanks to the tedious 3 stage powder-coat that seals the step from the open air and harsh road conditions.
Why choose us?
High-quality running boards that are built to last
A wide range of styles to match your truck's look
Savings that you won't find anywhere else
Ready to get started? Simply shoot us a private message or email us at [email protected], and our forum team will guide you through the process. Your truck will thank you for it!
Don't miss out on these one-of-a-kind deals β message us now!
