BamaGal
addition pics:
addition pics:
That looks dope. Fills the wheel well perfectly. Crazy these trucks can fit 275/65/20’s stock.
Yeah, I love it. My installer said it was close, but he didn't have to alter anything and there's no rubbing anywhere. If I wanted to go with an aftermarket wheel, I'd definitely have to do at least a small level. I think it'll look MUCH better in the back once I get the wheel well liners installed, too.That looks dope. Fills the wheel well perfectly. Crazy these trucks can fit 275/65/20’s stock.
tonight at my dealer I was told 20x8.5 with +44 offsetDoes anyone know what the stock wheel size is for the Sport wheel. Curious on the offset specifically.
Out of Curiosity, can you measure the actual height and width of the tires? Stock tires for me are 32.25 by 11 ish(275 60 20) at 35 psi. Trying to figure the actual sizes on some tires. Thanks
Tirerack.com provides these measurements for all the tires they sellOut of Curiosity, can you measure the actual height and width of the tires? Stock tires for me are 32.25 by 11 ish(275 60 20) at 35 psi. Trying to figure the actual sizes on some tires. Thanks
Just wondering if its accurate and actually 34" tall when installed.Tirerack.com provides these measurements for all the tires they sell
They're right at 33 inches on the truck, though they're a 34 inch tire. I'm thinking they may be a little under inflated, actually, at 38ish psi cold. I might add a bit of air, to maybe 45 or so.Out of Curiosity, can you measure the actual height and width of the tires? Stock tires for me are 32.25 by 11 ish(275 60 20) at 35 psi. Trying to figure the actual sizes on some tires. Thanks
276/65/20 copper st max with a 2 inch level, no rubbing at all, sits perfectDoes anyone have a picture of a ‘21 with 275/65 r20 BFG KO2 tires?
