Need help from anyone with leveling kit and bluecruise.
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
Hey Guys. I installed a leveling kit in November. Ever since my bluecruise would ping pong at any speed.
Long story but I added Comma AI self driving. I am having the same issues with the comma AI unit. It ping pongs bad. At first. Any speed above 55 it would ping pong. I have data logs and a guy from f150 forum is helping me sort through the issues. At first we tried changing some code. It improved slightly. I could get up to about 65 70 before it would ping pong on straight roads. It drives perfectly around curves.
I just got the truck re aligned today and I found out the shop that lifted my truck did a crappy alignment. So after the re align it's better but it still ping pongs.
I tried blue cruise again and it's like it's the same issue as thr AI. So for sure I don't have to get the camera aligned. It has nothing to do with that. The comma AI has its own camera and I can calibrate the system at any time. Both the comma and the ford system are having the same issues leading me to believe it's something to do with the alignment.
Does anyone with functioning bluecruise have pictures of your alignment settings after the lift that you can share with me? Especially if you have a lariat with a tow package
*** I have a 2 inch leveling kit***
Thank you
Whammy Bar
1971 F100 + 2022⚡Lariat ER
I have the Eibach lift kit. Truck ping pong before the lift and after. Did TSB 23-2073 to address the ping pong. Now it doesn't ping pong, it just drifts out of the lane without intervention half the time. So... Win?
Drayday55
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
Good info. Thanks. Since this tsb is for reprogram I don't think it will help me. Do you have the paperwork after the lift? If your alignment specs are on it can you share them with me?
2021 Ford F150 Platinum FX4 EcoBoost
Mine was ping-ponging before and after I did a 2.5" level. IPMA calibration procedure helped tremendously. You can do it with FDRS or FORScan.
Edit: For bluecruise.......not sure how comma works.
Drayday55
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
My bulecruis before was fine. Do you have any alignment records after the lift?
AZT9
Peoria, AZ
Leveled for the past year and a half. Zero issues before or after. 🤷🏻‍♂️
Drayday55
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
Do you have an alignment print out that shows your settings. It's typical after a lift.
AZT9
Peoria, AZ
I might have it in my truck. I’ll have to look. It was over a year ago. I do recall that I had difficulty finding a shop to do the alignment as the lightning was new and no one had the “specs” on alignment at the time
Yes, I had it aligned at work right after the alignment.
Lmcqueen23
Zack
Utah
Business Owner
Software Update 6.13
Were you able to get this figured out? I just had a leveling kit on mine and it ping pongs so bad. The blue cruise eventually cancels because I have to grab control.
V8BoatBuilder
Aaron
New Jersey
22 Lightning
I have a 2" leveling kit and no ping-ponging, it drives quite well. So it can be done...
