Yellow Buddy
- Feb 5, 2022
- Mid-Atlantic
- F-150L Pro, Rivian R1T, Model S, Model X
- Occupation
- Smart Ass
A little more background for my question: I stopped at 99% because the truck estimated another 45 minutes to go from 99% to 100%. Relatively little energy would have been added to the pack at that point and we needed to get on the road. What, if anything, would have been going on in that last 45 minutes I abandoned besides a very slow charge rate? Anything that might suggest next time I should allow more time and let it complete its cycle?I normally plug in each night and charge to 85% (thank you, @MickeyAO ). Yesterday I set the truck to charge to 100% for a trip but stopped at 99% so we could leave. It got me wondering: Is there any benefit to charging all the way to the “full” 100% every once in a while? Voltage balancing?
Possibly not relevant, but my phone is set to charge to 80% routinely but every once in a while charges to 100% because Apple decided it should. Just made me wonder.
I typically charge to 90%, but had some questions on the BMS, so I tried to recalibrate it.A little more background for my question: I stopped at 99% because the truck estimated another 45 minutes to go from 99% to 100%. Relatively little energy would have been added to the pack at that point and we needed to get on the road. What, if anything, would have been going on in that last 45 minutes I abandoned besides a very slow charge rate? Anything that might suggest next time I should allow more time and let it complete its cycle?
I‘m not interested in tapping reserves not generally available, or in pushing the limits of the battery. I’ll do 85% charge normally, charge in small increments when I can, and try to stay above 20%. But if I need to go to 100% for a trip (right before I leave), I’m not going to sweat it. Perfectly happy to let others decide what is right for them. I’m really just curious about what is going on with the battery at that charging endpoint. Thanks for any insights on this.
I usually charge to 60 percent. Usually I get in and it says 60. Sometimes it drops immediately to 59. Sometimes it jumps to 61 or 62.This is kind of a happy coincidence because I just sort of did that. Like you I had to leave before the truck stopped charging but this is the last few minutes, when the display was showing 99%. It was 100% just a minute or two later because my wife noticed it. I don't know if the charging would have shut off at 100% indicated like it does if I tell it to charge to 80%. I hope not. I do not know why the Energy kWh stopped being recorded, just before I left it was 90.65 kWh (top graph), 91.74% Hvb State of Charge (middle graph) and 99% indicated (bottom graph.)
You can see that the truck's idea of the internal charge of the battery keeps rising non trivially even after 99% is reached, so if your goal is to get as far as possible on one charge you want to keep it plugged in. Note this is a SR truck with a 98 kWh battery usable supposedly, so I think that my truck has drifted below reality. I have never seen an indicated range anywhere near the EPA but in reality on my most recent long trip I was able to get more than the indicated range. (I didn't drive to zero, it just kept readjusting.)
Balancing happens above 80%.I normally plug in each night and charge to 85% (thank you, @MickeyAO ). Yesterday I set the truck to charge to 100% for a trip but stopped at 99% so we could leave. It got me wondering: Is there any benefit to charging all the way to the “full” 100% every once in a while? Voltage balancing?
I’ve only TRIED to charge to 100% immediately before departure for a long road trip. However Fords crappy software has caused me to mistakenly do it a couple time. One of them this morning because I had to shut off my charging locations to charge past my typical 80% the other day in preparation for possible power outage due to weather. i typically would have gotten the extra juice manually using the Ford pass “charge to 100%” option which is currently broken for me. The next night I forgot to turn on my locations and forgot to set my one time charge limit so it went to 100% all in its own. So annoying.Balancing happens above 80%.
I can’t drive past 0%. So I wouldn’t count on that.Some people say that you can charge to 100% because there is extra capacity. Others say that you can drive past 0% because there is extra capacity...it can't work both ways. Do we know if we actively charge that capacity or if it's left empty so we don't charge to an actual 100% ever.
