Reeltime
- First Name
- James
- Sep 2, 2020
- Lake Fork, Texas
- 2021 F150, 2018 Murano
- Occupation
- IT Consultant
I have several issues towing my boat or a tandem utility trailer.
1) Left trailer turn/brake light failure constantly. If you turn on the left turn signal, flashes quickly a couple of time and starts working normally. Turn off left turn signal and fault comes back.
2) Ford 7 pin to 4 pin adapter, 4 pin side is to tight to plug in 4 pin trailer lights. Ended up buying one at True Value hardware. The Hopkins brand 7 pin to 4 pin adapter does not fit into the 7 pin socket on the truck. Apparently Ford never tested the adapter.
3) Locked truck with the trailer attached. On my return to the truck, as I approached, the alarm goes off. This has happened multiple times.
4) Trailer light check from Ford Pass turns on tail lights on truck, but the tail lights on the trailer do not come on. If you manually turn on the tail lights, the tail lights on the trailer work. Something wrong with the light check.
Nice to have - it would be great if the power tailgate would automatically disable when a trailer is hooked up to help eliminate opening the tailgate into a trailer Jack when the trailer is attached to the truck
