Good set of Jack stands and Jack.
Buschlatte
Downriver MI
F-150
I am in the market for a new set of Jack stands and a Jack for the new truck. Anyone have any recommendations??
mnstang
Nick
MN
2021 F-150 Lariat PB Leadfoot
US Gov
Hambone
Aaron
Idaho
2021 F150 XLT Sport, 2011 F150
Home Inspector
Beware of the HF jack stands! They had a huge recall on them last year but that has all been worked out by now. With that said, I do have a Pittsburgh (HF) floor jack that has been great. I used to work for NAPA and I also have two sets of their jack stands, very good quality IMO. They also have good quality floor jacks. When it comes to these items, don't be afraid to spend a bit more for a name that you trust, afterall, you are trusting your own safety to these items. Get a 3 ton or better jack for reassurance and double-check the specs on lift height/range; don't be that guy that stacks blocks on the lift pad all because they have a jack without the lifting height.
desertlivin
Las Vegas, NV
2018 Tesla M3, 2021 F-150 Platinum Powerboost
Network Architect
I am looking for a good jack and jack stands too, something I can take in the truck and also use for my 3500lb travel trailer.
I was originally looking at the Omega Side Pump Bottle Jack - 6 but then I also see the Pro Eagle jacks as pretty popular. I would be interested to see what recommendations others have.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
I have a set of four 3 ton jack stands and a 3 ton floor jack that are Craftsman branded. I've had them for years though, so I'm not sure if you can still buy them. Only complaint I have is that the floor jack is ~80-90 lbs so it isn't the easiest to lug around, but it has a really large range of travel. I may replace it with an aluminum jack from HF at some point.
Blaster
VT
F-150L PRO, VW ID.4
Anyone upgrade their stock scissor jack with a bottle jack yet?
I'm considering a +4-ton option but now realizing I have to measure frame to floor minus tire width to see what clearance I've got available and what will fit.
mr fiso
Washington
@Blaster - You make an interesting point, that I had not thought about, while considering a hydraulic bottle jack.
My over-kill train of thought was having something that can do 10k, since the entire truck in 6k+. Sure, each corner is far less than that. But... I can use it elsewhere for more serious work.
That said (did I say 'over-kill'?), I had not even thought about clearance. Or better yet, actual jack height limit. With 22 inch rims, the truck sits very high off the ground. How far can a bottle extend to get even one of those damn things off the ground?
moder8tor
Prescott AZ
23 F150 Lariat Lightning, 18 F250 Lariat Diesel
hard worker
moder8tor
Prescott AZ
hard worker
Stevie Wonder
Steve
North GA
2023 F-150 Lightning XLT, 2018 F-150 Lariat
Airborne in 4 minutes!
24" jack & 3.5 ton stands
@Jake24, The problem I encountered (particularly on the rear) was that once I got the floor jack under the "jacking position" arrow on the frame, there was no room for the jack stand (Hein-Werner 6 ton) to slide in so I could lower the frame onto it. The frame has a bit of a curve there so there was no safe position to rest it on the jack stand. How did you get around that in your 4 minute lift solution?
Thanx!
