merek
Buffalo, NY
F150 Lightning Lariat ER [6/20]
I'd caution that you have no idea of the actual impact since you haven't done a controlled test. Clearly, reducing 52 pounds doesn't result in your efficiency going from 2.8 to 3.8, a 36% increase. Temp changes could account for the differences, and the highway shows you that it's not different, possibly. I'm not expert on sprung vs. unsprung weight, or rotational impact, but nobody is getting a 36% increase in efficiency by using lighter wheels.
If it were that easy, I am sure Ford would have done it and advertised a 400 mile range. Or given us a 36% smaller battery.
sr3jan
Atlanta, GA
23 Lariat
Thanks for this. I've been strongly considering those steps. If not Amp then who? I like the look of these and their reviews for the ICE version seem solid.
As for the amp steps. They are the dual motor ones. I had to relocate the ABS module by drilling a new hole in the frame and also grind away a useless metal tab as well as push and zip tie the large HV line up about 1/4” to clear. Everything else was plug and play.
I will say Amp sucks in re to customer service. If I had it to do again, I would not buy thier product.
After seeing what can be done, I pulled the trigger and bought the steps. At the wire box, I tapped the incorrect wire, green with a blue stripe was a difficult find and I mistook it for green with purple. I called Amp to get some help and the self proclaimed “Lead Tech” said “It does NOT work, we have a Lightning in the shop right now and it ABSOLUTELY DOES NOT WORK” and he was kind of a prick when he said it.
Well that’s a lie. Another forum member here pointed me to my folly and lo and behold! Viola! I was sure to post a video on thier FB page calling them out. Anyway. Amp sucks. But…..if you do want them, get ahold of Realtruck and they will give you a nice discount.
jasonator
Jason
Tampa
2022 F150 Lightning
7000 lbs. Let us know if you bust one.
Just reporting back after 18 months of riding on the wheels. I just traded the truck and removed the wheels. I’m happy to report that after 36,000 miles there were no cracks, bends or broken wheels. I drove it like one does a truck. I’ve jumped a few curbs, gone down dirt roads, pulled heavy dump trailers full of broken concrete. They have held up as expected.
VAF84
Central Texas
2023 Lightning Lariat ER
Consultant
Thanks for the follow up. Shame they didn’t improve highway range as that’s where I would really need the improvement. I’m consistently at 1.7, or 1.6 when on the toll doing 80 in the summer.
What did you move on to?
jasonator
Jason
Tampa
2022 F150 Lightning
Gotta a helluva deal on a 23 Platinum. Had to drive 3 hours to get it but MSRP was $94 and then aftermarket spray in bed liner and tint.
Picked it up for $80k and they gave me $3k more on my trade the rest of the city/kbb. So roughly $17k off. 72 months 0% and no payments for 90 days. I did get hosed on GAP…$1100 but after the deal I was hard pressed to beat them up anymore.
Someone special ordered it and then never took delivery. It has been on their lot for about 9 months.
dustintinsley
Dustin
Salem, CT
See you no long have these wheels but do you remember what offset you went with? 0mm or +12mm?
