Using backup camera while rear window blocked by tonneau cover
KDF150
2023 F150 Lightning
I’m 100% sure I’m not the first one to be annoyed by this…
Sometimes I need to drive with the tonneau cover up and/or with load that might be higher than the truck roof.
in these situations, I would love to use the backup camera from the tailgate to keep an eye on upcoming vehicles behind me if I need to slowdown or brake.
While I do understand the backup camera might not provide a full view, why on earth the UI designer put the notification precisely where we would actually need to see vehicles behind us to assess their speed !? I mean there is SO MUCH UNUSED REAL ESTATE on the screen to put proper disclaimers… it’s actually dangerous.
interestingly, this notification is absent when using the cargo bed camera… makes zero sense to me
while we’re at it, it would be awesome to have a “pop out window” of the rear view mirror we could see while using navigation “à la Cybertruck”
anyone feeling the same ?
Anything we can do about it?
Ford F-150 Lightning Using backup camera while rear window blocked by tonneau cover IMG_6886
I
Ford F-150 Lightning Using backup camera while rear window blocked by tonneau cover IMG_6885
So many people complained about the “Full view not available” message that Ford issued a TSB instructing dealers to tell customers that it’s normal and to do nothing.
In the software world, it’s called a “WADAFU.” Working As Designed, All F*+%ed Up.”
Runaway Tractor
Yes
Yep. Known problem that Ford is aware of and has done nothing to fix.
You can remove that stupid notification box with some configuration changes in Forscan. There's entire threads on it.
Shawnson
Edmonton
Lightning Lartiat ER, Model 3 LR, Crosstrek… hehe
Developer
I’m thinking they did it on purpose so you couldn’t use it as a rear camera. Their “commitment” to safety goes beyond absurd sometimes. Also want to use the bed camera by default when the tailgate is down… No use seeing what you already ran over….
Wendy
Puget Sound
1967 Saab 96 (dead), Silverado (squished), F150 L
I'm with you on this, why put the box EXACTLY WHERE THE CAR IS BEHIND YOU??? Let me hit "OK", or put the notice way on the top or bottom. I know when I have the window blocked that it's not a 100% replacement for the actual rear view out the window.
I hope FORD is listening to our comments. And next time I'm in the truck I'm going to use their "record your feedback" option and tell them to move or remove the warning!
cal
Cal
Battle Ground WA
2022 Lightning, Tesla Model S Plaid
Boy this should be fixed with an OTA update.
Ishkatan
Adam
Monrovia, Md
2023 F150 Lightning Lariat ER =RAe (Range Anxiety)
Old
How do we get Ford to notice we are unhappy with this stupid (and useless) message?
Also, when using the cargo camera, show maps in the useless area where they show a truck with no info around it.
