spectre446
I've never owned a pick up truck before. Can you put it through an automatic car wash? Does it matter if you have a tonneau? Thanks
The non powered running boards have no problem getting through a car wash.Even though I don't have my truck yet it's why I ordered the power running boards, was concerned the non power type would not be able to go through a car wash without getting damaged.
Good to hear! I have no worried about the power boards, or all kinds of trucks with stationary boards would have issues. But that is encouraging on mirrors. I also will use the car wash as my tonneau test for water resistance.I take my truck through the wash all the time especially to get the salt off in the winter. It is a touchless wash with underspray and works great. I always leave my power trailer mirrors out and put down my power running boards manually to get them cleaned off. I have a trifold cover and some times a little water will leak in but nothing serious. I have been taking them through for years and never had an issue
What trifold do you have? The fact that you can make it through an entire car wash and only leak a little bit is impressiveI take my truck through the wash all the time especially to get the salt off in the winter. It is a touchless wash with underspray and works great. I always leave my power trailer mirrors out and put down my power running boards manually to get them cleaned off. I have a trifold cover and some times a little water will leak in but nothing serious. I have been taking them through for years and never had an issue
Yes it is a good test for your cover...you will get some coming in from the tailgate unless you have it sealedGood to hear! I have no worried about the power boards, or all kinds of trucks with stationary boards would have issues. But that is encouraging on mirrors. I also will use the car wash as my tonneau test for water resistance.
Good to know but I also don't really like the look of running boards so the power boards should stay hidden til neededThe non powered running boards have no problem getting through a car wash.
Just had mine in touchless this pass week, had to turn in my mirrors but if you have reg mirror you be fine.I've never owned a pick up truck before. Can you put it through an automatic car wash? Does it matter if you have a tonneau? Thanks
How are you sealing the 2 gaps the tail step leaves? I have ideas but may just leave itIt is the Undercover Armourflex I had it on my 2019 and put it on my 2021. The only problem is the water does leak in around the tailgate a litlle bit. I am going to try and get a seal for the tailgate but did not get it yet,
