Painting or covering light blue Flash logo?
Sleepa
Sleepy
TX
‘24 F-150 Lightning Flash
Does anyone have any experience painting, swapping, wrapping or otherwise modifying the flash logo that’s on the charge port door and the opposite side? tried to remove the one on the passenger side when I debadged and learned the hard way they’re anchored in
Ford F-150 Lightning Painting or covering light blue Flash logo? IMG_3220
AZT9
Peoria, AZ
Yes. Mask off the area around the logo and start with a dust coat. Build it up with multiple coats, the more the better. After the last coat, simply peel the excess off and it will leave a blacked out logo🤙🏼
flypony53
Rodney
Houston, TX
Ford F150 Lightning, Tesla Model Y, Tesla Model S
I have done this on several cars. I have not on my lightning, mainly because I updated my ford emblems with the black versions. the results are great and last for years in my case. My 21 Tesla MYP still has the one I did when I first got the car.
As previous poster stated, dust with many coats and wait about 15 minutes in between. I typically do 7-10 coats without issue. Pealing away is easier than it looks, but I would say ensure you pull away, not up or you have to start all over.
acbarba
Enrique
2024 F150 Lightning Flash
Assistant Fire Chief
  • I have been thinking the same thing! I'm not a fan either! The 2024 limited edition platinum model has all black badges and they look really nice!
acbarba
Enrique
Where were you able to find the black emblems?
flypony53
Rodney
Houston, TX
acbarba
Enrique
Thank you! I appreciate that!
flypony53
Rodney
Houston, TX
One thing I would point out, not sure if anything else has changed, but I do have a 2022. I believe it is all the same, but wanted to call that out.
chapba
mike
2024 Flash
fire
Thanks for mentioning the passenger side being anchored. I was planning on taking it off as well! Did you fill the holes or simply put it back?
Oafy44
Georgia
23 ford lightning
Landscape contractor
I’m thinking of same thing but might wait to see what badges on “midnight” edition for 2025 job 2 looks like and order those badges - my guess that edition will all have black badging. - of course probably won’t be able to order them for a while so maybe I’ll just jump the gun.
Sleepa
Sleepa
Sleepy
TX
once I felt the anchor with the floss I asked on reddit and stopped the removal, i had only just started so it really didn’t make a dent in the glue.
BennyTheBeaver
They did change the emblems between '22/'23 models and '24 models. However, I'm not sure if it was purely cosmetic or if there were other structural changes too.
Bostondrew
Drew
Boston
2024 F150 Lightning Pro
How about the back Lightning on the bed sides? Been thinking about taking those off my 24 but haven’t looked into it too much
