Ford vs linex spray in
billybob
2012 Focus SEL
I was thinking of going with ford spray in for simplicity but it looks like they don't do the area on the tail gate around the work surface? Do you think a third party/linex will or is there something with the new work surface that won't allow it?
currybob
Bob
Alexandria Alabama
2021KRF150 PB; 2020 LexusRX350; 2021 Mazda Miata
Retired Physicist from federal government; Army Veteran
I'm sure they will if you want it done. I see no reason why they couldn't.
billybob
2012 Focus SEL
I noticed in some of the newer reviews/videos that the ford liner does now do the tailgate around the work surface. Must have just been some of the early builds that did not.
Knickell
Kyle
Mazda Protege, Ford F-150
I elected not to have the spray in bed liner from Ford. The research I’ve done shows that Line-X is a bit thicker, and has a better warranty.
Just a clarifying question. Many of you said the Ford liner doesn’t cover the tailgate? Isn’t that ideal because of the built in holders, ruler, and clamps on the tailgate?
billybob
2012 Focus SEL
Ford F-150 Lightning Ford vs linex spray in 2021-Ford-F-150-Exterior-Tailgate-Work-Surface-003
You can see here. I was talking about the tailgate that is outside of the plastic insert as shown here and not actually putting bed liner over the plastic insert.
Knickell
Kyle
I see, I don't know if it would be normal to Line-X around and underneath that or not.
Bryan Simon
Bryan
San Antonio, Texas
65 Ranchero, 66 ElCamino, 05 Ranger, and more
Maintenance
The work surface most likely would be removed and screw holes covered before spraying, and replace the surface for a clean look.
Anyone that would attempt to mask around that, is just cutting corners.
currybob
Bob
Alexandria Alabama
Line-X will make it look just like Fords, you just tell them what you want. As memtioned, romove cover apply line-X and replace cover.
Knickell
Kyle
Nice to know! You think Line-X will put that cool Ford logo in the center of the bed room like the factory one?
currybob
Bob
Alexandria Alabama
GABAR
P
GA
2016 F150
I know it doesn’t matter but for those who want the Ford logo in the bed and against the back wall, one has to go with the factory spray in bed liner.
CLEMike
Cleveland
I have contacted a local LineX dealer and they will do anything you want as long as it doesn't interfere with operation of the tailgate. I've seen pics of ALL the interior surfaces covered including inside the jams. But I went with factory for a few reasons.
1. It's done when I get it and I don't have to wait days to get the truck that I waited month for back.
2. The most abrasive thing I put in my bed on a regular basis is firewood.
3. If the factory liner fails, LineX can fill in chips, skim coat over factory, pretty much whatever you need.
Jim Bandy
James
2021 F150 Limited 4x4 Powerboost (Hybrid)
Likewsie, I went with the OEM. I'll also use (added) the Ford thick Heavy Duty Rubber Mat on top of spray-in liner. I used it on my 2016 and looking back, I loaded loose rock, sod, brick, etc. As always I managed - closely supervised all of my loads, ensuring n the bed sides were ever touch only the bed.
Ford's rubberized bed mat (about 1/2" thick), absored a lot and it never tore or chiped away.
I brought it to give me assurance that the bed itself was well protected.
Many may say - isn't that overkill - my answere it provided me a peace of mind so I was good with it. It wasn't all that expensive and I didn't pay the full dealership price. I'll do it again on my 2021 F150. Usually runs around $239.00 (heavy duty). Also, from a cost ($) point.
When I pick up my truck I add the Ford's accessories on the truck purchased sales sheet. Why?, my state rules is - any item added @ time of purchased one pays (my state) a 3% sales tax,
if purchased seperately the state sales tax is 7%. Yep, I do count all of the pennies & dollars when buying a vehicle :)
currybob
Bob
Alexandria Alabama
My state also, except the tax rate is 10% state/city tax. Dealer will send the truck over to Line-X for me and put that on the sales sheet to save me also. Every little bit counts.
